Old 20th March 2008, 02:33 PM   (permalink)
Default What is the maximum Timer can i get ?
Most of Emergency lights in our houses fail to work at the right time. Because their Batteries have not exercise charge/discharge for long time, they are not able to take over or in luck cases, they start but end after a short time.
An idea came to my mind to make a SIMPLE timer circuit that will auto-exercise them by turning their power Off / On frequently.
The question is: What is the maximum time can I get of a timer ? even if it is not accurate. One week will be very nice. But is that possible ?
Its what your friend in Your mind, what you in your friends mind
aljamri is offline
Old 20th March 2008, 02:37 PM   (permalink)
Easily possible, use a PIC to do it - you can then write software to give pretty well any time you like.
Old 21st March 2008, 12:21 AM   (permalink)
Or a simple CMOS oscillator counter like the CD4060 - very useful if you don't want to program and ICs.
Screen name: Aloone_Jonez
Hero999 is offline
Old 21st March 2008, 03:28 AM   (permalink)
Frankly, Ive got tired of the short life span of most rechargables and have gone to dynamo powered torches. A few cranks keeps them with some charge and when the power does go off a few more keeps them going for 1/2 an hour by which time I can start the genset.
Super_voip is offline
Old 21st March 2008, 08:59 AM   (permalink)
Thanks Nigel, but for the cost ($0.4) and availability, I'll go for Hero999 suggestion, cheaper and easy to build. I got its circuit
http://www.coolcircuit.com/circuit/timer_4060/timer.GIF
even this will not fully solve my problem since the maximum time is 320 Minute (5 hours 20 minute).
It says to get more time cascade another Ic. My question is: it says that
T = 2.2 x R2 x C2
Then why don't we simply play with R2 and C2 values?
aljamri is offline
Old 21st March 2008, 09:04 AM   (permalink)
I am looking for such device in local market with no hope. I am living in a small island where if anything not available in the market, you have to use EXPRESS mail, that doubles the cost and makes it worthless ( around $40 )
aljamri is offline
Old 21st March 2008, 01:44 PM   (permalink)
I found another circuit promise to make 20 Hours laps, but with this cost will exced PIC price . the circuit is attached and this is the site link:
http://www.uoguelph.ca/~antoon/gadge...ys/relays.html
aljamri is offline
Old 21st March 2008, 02:05 PM   (permalink)
I think we can acheive long delays of several hours by using a low frequency oscillator and a binary counter.
may be we can use one stage of a schmitt trigger inverter as a square wave oscillator to produce very low frequency...
then we can use a 12 stage binary counter likke the CD4040, where the frequency will divided by 2 at each successive stage... i believe we can get a good delay time before the final stage of CD4040 switches to the high state....
raviram87 is offline
Old 21st March 2008, 02:37 PM   (permalink)
T = 2.2 x R2 x C2
Yes, play with the RC values, for example increasing C to 10µF would doulble the delay.
You could also use the CD4521 which has a 24-bit counter.
Also checkout the CD4536 and CD4541 which are designed for this.
Hero999 is offline
Old 22nd March 2008, 07:11 AM   (permalink)
I found CD4541 @ Futurlec.com for $0.45 i'll order it and play with RC circuit to get maximum dealy possible.
Thanks for all
aljamri is offline
Old 22nd March 2008, 03:57 PM   (permalink)
You still haven't said what delay you require.
If you set the oscillator frequency to 1Hz on a CD4541 and used all of the stages, it would give you a delay of 2^24 seconds or 194 days, 4 hours, 20 miniutes and 16 seconds.
I don't know what the minimum frequency the of the oscillator is but I suppose its possible to get delays of over ten years if you really want.
The only problem is capacitors aren't very accurate, 10% at best, so a calculated ten year delay might be anywhere inbetween 9 and 11 years.
Hero999 is offline
Old 22nd March 2008, 06:27 PM   (permalink)
The oscillator capacitor in a CD4060 and CD4541 is supposed to be non-polar. The article uses a polarized 4.7uF electrolytic capacitor which is wrong.
audioguru is online now
Old 22nd March 2008, 08:54 PM   (permalink)
I don't know, I didn't check the datasheet.
Anyway, you can get non-polarised electrolyics with values up to 470µF. The problem with any RC oscillator is the leakage current in the capacitor which might make electrolytics problematic.
Hero999 is offline
Old 22nd March 2008, 09:18 PM   (permalink)
Two polarized electrolytic capacitors connected in series and back-to-back make a non-polar capacitor half the value.
Old 23rd March 2008, 10:21 AM   (permalink)
not exact period but if i can make it ON once every week say for half an hour, this will make the Batteris in a better case.
aljamri is offline
Help with timer and interrupt please.. AntRoFiZ Micro Controllers 2 29th May 2007 12:48 PM
:: Timer 2 Woes :: suby786 Micro Controllers 2 5th May 2007 12:13 PM
Watchdog timer in PIC elexhobby Micro Controllers 7 6th November 2005 03:51 AM
Massive ERRORS in program. URGENT HELP NEEDED. davepusey Micro Controllers 8 18th May 2004 05:13 AM
countdown timer code ah_Hui Micro Controllers 0 26th April 2004 06:31 PM
