| Thank you. I'll learn those codings! Output impedance is 50 ohms. So that might be a problem.Normally what method do you use to match monopole antennas? Stub? QWT? Please. | |
| what method do you use to match monopole antennas? Show me some sites where I can learn them? I have only theoretical knowledge in matching! Please | |
| Well there are a couple things you can do. If you shorten the monopole to .46 wavelengths (or there about, you'll have to look it up to be sure) you can find the resonance length and that'll cure some of your matching problems. You'll still have a power loss because the real part of the impedence will not be 50 ohms, I would expect it to be 60 - 70 ohms, but that might be a close enough of a match for your purposes. Otherwise you might have to use some sort of matching network. | |
| Thank you Maj. I'll try with that. I learned single stub matching, double stub matching(those horrible smith chart), QWT method etc etc. But don't no how to apply them in the real world . (I made a patch antenna for my module project and Just a BNC connector did every matching thing for that,thats all). Anyway thankyou! Share if you have anything to tell me. | |
Antennas aren't really much of a science, we really undertstand two types of antennas exactly, that being the dipole/monopole and the loop, other than that antennas are generally guess and check. | ||
| Thank you!Theses antenna are parts are really disgusting. I'll do that 0.46 lambda thing. I'm going to use a V antenna (not those inverted Vs) while I implement the system,. I lost those equations for V antenna design.(I Designed one for my TV, It works perfectly) Can some body help me sending them? In my other part of this project,I'm struggling with some SMD counters. Have requested for some counters in the "part/data sheet request" section. I'll try my best. | |
already replies are awaiting you over there v antenna calculator here http://www.hamuniverse.com/dipivcal.html
| Thank you sarma! I've replied. But Is V antenna and Inverted V antenna similar? I have studied that Inverted V antennas are normally used for VOR,DVOR radar communications. The one I built was not a UP side down V. It is kept parallel to the earth. I'll try to find the equations and send you. They very simple to build and very good in recieving. | |
| Hi! I have to get a 4Vp-p Sinusoidal signal (more than 22KHz) from a DC power supply(5-6V). Can I use a wien bridge oscillators? I'm sure that Getting an accurate sinusoidal from such hand made ccts are really difficult! Anyone have a tested circuit diagram for wein bridge oscillators? I went though http://www.educypedia.be/electronics...osciltypes.htm all shows different different ccts.???? | |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 10:49 PM |
| Help me to calculate the interrupt time | Suraj143 | Micro Controllers | 20 | 11th October 2007 05:54 AM |
| Measuring Pulse width modulation PWM | walters | General Electronics Chat | 44 | 12th June 2005 09:38 PM |
| Pulse train to DC level: | kybert | Electronic Projects Design/Ideas/Reviews | 8 | 21st May 2004 09:59 PM |
| Tweaking a ramp pulse generator! Ahh! | winners | Electronic Projects Design/Ideas/Reviews | 7 | 15th May 2004 04:30 PM |
