| Hey Folks, I'm looking to build a charger to charge a 14.4v 3800mAh pack. Well, I really want to charge 4 of these up. But, from what I can tell, charging NiMH packs in parallel is bad.. So, I though I could build 4 charging circuits and wire them in parallel using Diodes. I've read the Data sheet on the MAX712, and It looks like what I need. I want to be able to charge these packs at around 1.25 to 1.5Amps. Source voltage will be a 18v power supply with up to 8amps output. The circuit needs to be able to handle the load while charging.. The load can peak at around 1.7Amps. I thought about using larger batteries such as D's or F's.. However, charging multiple packs at the same time would yield a faster charge.. and the most mAh I can get with other cell's is either 10000mAh with D's or 14000mAh with the F's. 4 3800mAh packs gets me longer runtime. Any help would be appreciated! Thanks, Connor | |
| The datasheet for the MAX712 shows each cell's voltage exceeding 1.5V. The datasheet says that the input voltage must be at least 1.5V higher than the max battery voltage. You are charging 12 cells so you need an input voltage at least 20.1V. The IC has only a single input to detect when the battery is fully charged. Then you can't add more batteries with or without diodes.
| | (permalink) | ||
Thanks, Connor | |||
| If the input voltage is not at least 21.1V then your batteries will not fully charge. Don't use diodes at the output of each MAX712. Each one charges its own battery. They cannot share a load because each one must detect that its battery is fully charged.
Thanks, Connor | ||
| I want to use this ic for a project im building, but after reading the datasheet i found the part about the number of cells programed a little confusing. it says: "The internal ADC’s input voltage range is limited to between 1.4V an 1.9V, and is equal to the voltage across the battery divided by the number of cells programmed". does this mean i cant use it with a single 8.4V 200mAh NiMH battery? Would using 8x 1.2V 1400 mAh (AA) batterys be better? And finaly if i do use the AA batterys in series will the current/h rating be additive (iow 8x 1400mAh = 11,2 Ah)? | |
| The Ah rating of a battery is for its current. Cells in series all have the same current as one cell. So the Ah rating of a battery with one cell is the same Ah rating of a series srting of many cells. I didn't read the entire datasheet. You must program how many cells you have and I think a resistor determines the charging current.
| Battery Charger with auto shut-off feature | hardcore misery | Electronic Projects Design/Ideas/Reviews | 134 | 12th February 2008 09:20 PM |
| Nokia charger | bananasiong | General Electronics Chat | 6 | 7th August 2007 04:04 PM |
| Lead Acid Battery Charger Help Request | jagzviruz | Electronic Projects Design/Ideas/Reviews | 17 | 16th January 2007 11:46 AM |
| Anyone interested in designing a µC-based NiCd/NiMH battery charger? | Odysseas | Electronic Projects Design/Ideas/Reviews | 21 | 18th December 2006 03:09 AM |
| Battery charger for mobile phone Motorola | 2PAC Mafia | General Electronics Chat | 0 | 4th October 2005 04:20 PM |
