I just cannot figure out how to charge these
These little stinkers Ive tried a 5V regulator with the output limited to 60ma (resistor) and it diddnt charge it at all google spammed me with 4.8V batteries, so I am stuck here. Any schemmehs or tips? specs: 4.8V 60ma NICad |
C/20 will work, but you might need a little more voltage.
Therefore if the batteries are 60ma then you can safely charge them at 60ma / 20 so 3ma won't hurt them. |
Most of Cell chargers should work. Else, you have to create a constant current source. Simple way is to use a 7805 with a 2 diodes in the common path to ground. this will lift the supply to 6.4V approx. on the output put a diode for preventing reverse discharge and add a small resistor to limit the current to say 5mA.
you will find the battery charged in about 5 to 6 hours, as it was not charged earlier.discharge with an LED at say 25 mA until the voltage falls to just 4*0.8=3.2v and repeat the process.
Regards, Sarma. |
The 4.8V battery needs a charging voltage of about 6V, not 4.8V.
It will overheat and POP if you charge it at 60mA. Charge it at 6mA and turn off the charger when it is fully charged.
Uncle $crooge |
I used to work for a electronic distributor that had a value added department.
In that department they built and rebuilt all kinds of rechargeable battery packs. And they also built lots of custom battery chargers for ni-cad batteries. They were very sucessful building Ni-cad chargers that charged at C X .095. constant current. They found that charging them at this slightly reduced rate a room temperature the batteries never overcharged and as a result the chargers could be left connected for extended periods of time. Using this concept on Nickle metal hydride has worked well also. A large number of the chargers used the LM317T in the constant current mode with the controlling resistor chosen so that the charge current was at the .095 or slightly lower rate. They also ensured that the charge voltage was at a minimum of 1.5 volts per cell or slightly higher. As a side note: As the Ni-Cad cells reach full charge three things happen, 1 the temperature of the cells rise slightly. 2. The internal gas pressure increases. 3. The voltage on the cell rises to a peak and then drops slightly.
The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. |
On their website, Energizer shows that Ni-Cad cells that are continuously overcharged at 0.1C for two years are still good. But Ni-MH cells have 5 times the capacity of old Ni-Cad cells so their 0.1C charge rate is also 5 times higher. So Energizer recommends switching to a trickle charge rate of only 0.04 when the calls are fully charged.
Uncle $crooge |
Hi Krumlink,
Try this one, I know it's a rather expensive and complicated circuit but it's better than nothing. on1aag. |
That 4.8V battery needs at leat 6.4V to charge.
Just use a resistor, rectifier and mains tranformer - simple easy and cheap.
| Battery Charger with auto shut-off feature | hardcore misery | Electronic Projects Design/Ideas/Reviews | 134 | 12th February 2008 08:19 PM |
| Lead Acid battery charger | manojp01 | Electronic Projects Design/Ideas/Reviews | 5 | 29th January 2008 05:16 PM |
| Battery charger help... | dieselmo34 | Electronic Projects Design/Ideas/Reviews | 14 | 18th December 2006 05:30 PM |
| Battery charger for mobile phone Motorola | 2PAC Mafia | General Electronics Chat | 0 | 4th October 2005 03:19 PM |
| constant voltage, constant current Lead Acid Battery Charger | Erwin_Macaraig | Micro Controllers | 0 | 4th January 2005 09:35 PM |
