Old 14th March 2008, 05:18 PM   (permalink)
Default LED project
hello all, I'll appreciate any help that you guys can provide me with this small design. I am open to any suggestions, i want to make a text fixture that when you input different exact voltage readings you obtain an visual LED light. For example if you were to input 5 volts exact with a little tolerance a LED will light up .. that's it. I was thinking a simple LED circuit but if the voltage is 4.80 i need another LED to light up. Could i use a transistor to control the LED when only a particular voltage is fed?
raphaelriv is offline   Reply With Quote
Old 14th March 2008, 06:15 PM   (permalink)
look up a voltage divider circuit, you could use a transistor to turn things on at the various voltages then
Norlin is offline   Reply With Quote
Old 14th March 2008, 06:27 PM   (permalink)
Hi Raphaelriv,
Try this one, the only limitation is that the voltage drop of
the red led should be lower than the voltage drop of the
green led.
on1aag.
on1aag is online now   Reply With Quote
Old 14th March 2008, 07:20 PM   (permalink)
Default re:
thanks guys! great help
Newbie LED Control chase / fade project tallan Electronic Projects Design/Ideas/Reviews 8 12th March 2008 05:53 PM
230 Volts LED night light project RODALCO Electronic Projects Design/Ideas/Reviews 12 2nd March 2008 11:43 PM
LED Matrix Project Debug, Please Help :[ mekohler Micro Controllers 2 7th December 2007 06:56 AM
Pressure differential LED project. tsneidin Electronic Projects Design/Ideas/Reviews 23 3rd December 2007 11:32 PM
Uni Project Advice 2-tone Electronic Projects Design/Ideas/Reviews 7 18th October 2007 12:10 AM
