I want to convert Voltage to digital (BCD Code) for send to PC how can i convert (Can you tell me what the tool i can Use ) Thank you good luck | |
You mean Analog to Digital?
__________________ Khizer Naeem Mughal IIUI | |
| | #3 | |
try adc 0804 or 0808 . you havnt said any thing about how you want to use it and why u want to use it.
__________________ I just cant come up with a good one! | |
I agree, Using the 0804 (if it is single analog signal) will give you the 8 bit digital value. There are other issues also. What is the range of the analog signal that you want to digitize? If it is not in a complex application you can do this without using a micro controller! (by running it in the free run mode)
| | #6 |
Hi Nuttaphong191, This is one of many: http://datasheet.digchip.com/280/280...-0-ICL7135.pdf Google can be your friend, given the opportunity. on1aag. | |
| | #7 |
For the PC connection, You need some "intelligent" device, eg: microcontroller. Many type have analog inputs.
| | #8 |
yeah a microcontroller will do. but first he should tell what is he doin? i mean what kind of input is being given to adc?
| bcd, code, convert, digital, voltage |
| The Oscilloscope | ElectroMaster | Electronic Theory | 12 | 3rd February 2008 02:45 PM |
| Convert binary to BCD code | genetica | General Electronics Chat | 7 | 16th September 2007 03:37 PM |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 06:35 PM |
| AVR: PWM for convert a digital signal to analoge! | kasser | Micro Controllers | 3 | 12th July 2007 03:03 PM |
| convert 240Vac into variable voltage of 24 Vdc to 30Vdc? | Tian | General Electronics Chat | 1 | 6th October 2003 03:15 PM |
