| Notices |
| | (permalink (permalink)) |
| hi i need some help locating the eeprom on the circuit board shown below. ![]() that circuit board is from a Li-Ion battery used for the psp. Once i find the eeprom, i need to pull out the GND pin from it so that the eeprom is disabled and so the microcontroller returns a serial number of 0xFFFFFFFF to the PSP, which then goes into service mode. Once in service mode i can install custom firmware on to the psp. thanks in advance. | |
Just cutting the 'ground' pin of the EEprom will leave the the data/clock floating? Cant you just remove the EEprom or cut the data/clock pcb track, then ground or pull high these two lines to the controller? The number you quoted is most likely a PSP 'house' type number.
Do you guidance on how to do that.?
Can you post a picture of the other side of the pcb? I will try to indicate on the pictures the best way to use the DVM.
| ok the one shown above is pretty much busted by now(tried some unorthodox bullshit) i do have another battery and i'm looking forward to do the same thing with it too( i mean deactivating the GND of eeprom) here are the pics ![]() ![]() now you can see that the pin is already removed and also i smoked it aswell! but that's alright as it didn't cost too much....i need some practice with this before i get another one Last edited by blufade; 14th March 2008 at 11:51 AM. | |
| I'd guess pin 1, in the bottom left, since its hooked up to that big plane. Hook up a DMM between a known ground plane and pin 1, and see if you get any voltage reading - if you do, its not ground, if you get 0v, its ground. And guys, he's looking to remove the leg to get the PSP into recovery mode, but if you cut the trace, youre going to have to fix it. Seems easier to take the chance and lift the leg, since its a lot easier to put back. | |
ok thanks with all that help, i guess now i know how to figure out the GND pin but it doesn't end there.....i'd like to know how to identify the particular eeprom to be modified on any psp compatible battery so that i don't have to look all around the country for an original battery from sony | ||
| I personally feel safer lifting the leg than cutting traces but thats just me. As for modifying the EEPROM, I dont think anyone here would be able to help you. You need to have someone dump the EEPROM and decrypt it to know what everything means. Id try a site like psphacks.com The people here could probably tell you how to remove the chip or read it while its on the board, and program it, but I doubt they know much about PSP Hacks EDIT And why is it so hard to find an original battery? I can go to walmart or Zellers or Gamestop or Futureshop or Best buy... you get the picture, and get a battery. | |
| NUBE with EEPROM Problems | PaulF | Micro Controllers | 16 | 14th December 2007 11:02 PM |
| Simple EEPROM Programmer through Parallel Port | mr.lemarc | Electronic Projects Design/Ideas/Reviews | 18 | 9th December 2007 03:26 PM |
| Need some assistance with 28C64B EEPROM project. | Photometric Guy | Electronic Projects Design/Ideas/Reviews | 7 | 2nd November 2007 09:48 AM |
| Spurious write or corrupting EEPROM ??? | Mr.Anderson | Micro Controllers | 5 | 19th August 2006 01:33 AM |
| sequential read to AT24C01A serial EEPROM | giaracam | Micro Controllers | 2 | 26th October 2004 03:19 AM |
