Old 13th March 2008, 06:40 PM   (permalink)
Default Help and information needed on a Resistor value
I wish to wire a super bright flashing 10mm LED to a circuit on my car, the battery supplies 12 volts the However I need to know what value of Resistor I need to enable me to do this. The specification for the led bought from Maplin is http://www.maplin.co.uk/module.aspx?ITAG=SPEC&ModuleNo=35843&doy=13m3#spec
Super Bright Diffused Red 0.5V
Kingbright description: L-816BSRD-B
Forward voltage: 2.5V
Forward current max.: 55mA
Reverse voltage max.: 0.5V
Wavelength @ peak : 660nm
Power dissipation PT: 310mW
Light output min.@ 9V: 100mcd
Light output typ.@ 9V: 300mcd
Can any body please advise me as to the type of Resistor needed for this type of LED to enable me to connect to a circuit powered by a 12 volt car battery?
Eralyn is offline   Reply With Quote
Old 14th March 2008, 12:05 AM   (permalink)
As you mentioned a circuit i would suggest you to use a regulator. Using simply a resistor may not be that efficient
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline   Reply With Quote
Old 14th March 2008, 12:07 AM   (permalink)
Or may be a voltage divider followed by an appropriate zener...
Not sure.. Waiting for correction
Khizer Naeem Mughal
IIUI
Old 14th March 2008, 01:05 AM   (permalink)
Smile keep it simple
Hello ...try to use a resistor 220 ohms 1 W..it will do it..calculated at max 13,8 V and abt 50mA......a 0.7 W will suffice because it's no continuos load...it's flashing....Good luck....Holger
Holger is offline   Reply With Quote
Old 15th March 2008, 01:02 PM   (permalink)
All I want to do is wire the led to a 12 volt battery source without frying the led. so all Ineed is a resistor, but do not know the value of the resistor to use. I think the type of resistor i need is carbon film reistor.. the type that has coloured bands around.
Old 15th March 2008, 01:22 PM   (permalink)
As you buy from Maplins, look at this 2W range, use a 270R to allow for a vehicle charging voltage of 14.8v.
Resistor = (14.8v - 2.5v)/0.045A = 270R
If you can find a 1Watt version that would be OK.
http://www.maplin.co.uk/module.aspx?...&doy=15m3#spec
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
Old 15th March 2008, 02:00 PM   (permalink)
Thank you very much for your advice it is very much appreciated.
Old 16th March 2008, 08:46 AM   (permalink)
Check the LED flasher datasheet, it operates from 3.5V thru 14V, suggests NO series resistor is required for a vehicle [12V] application.
Eric
PIC tutorials:
