I am a student trying to build a circuit for an A-Level electronics project. Essentially I am trying to construct a two-button learning remote. When one button is pressed, the device would go into `Learning` mode, where another remote could be pointed at an IR receiver in the device, and the signals transmitted could be recorded and stored. When the second button is pressed, these recorded signals would then be transmitted back through an IR transmitter. The remote needs to run off a very low voltage, for instance that provided by a small `button` type battery. I am pretty inexperienced when it comes to IR related stuff (well, electronics in general Any help would be greatly appreciated, David. |
I think most remote controls transmit using a 38kHz Ir signal. In the past I have used GP1UD281YK0F to receive the signal with, do a google for it. You'd probably then feed that signal into a microcontroller to deal with whatever code is received. Pretty complicated project for a beginner if you ask me.
If you have masses of memory you can simply sample it and store all the samples, then play it back - but the memory requirements are huge. |
what if assume that all the remotes to be used will use RC5 protocol on 38 kHz?
I think the life would be lot easier in that case...
Khizer Naeem Mughal IIUI |
i agree.... but on doing similar projects i found that most of the philips TV sets use the RC5 protocol, while other commercial TV sets have their own protocols....
RC5 is a very elegantly made protocol... |
Thanks for the response guys.
What sort of memory requirements would we be looking at to record a signal of typical RC5 length? Ideally I would like to be able to sample any TV remote, so I had always envisaged the system being quite open anyway. The device only has to record one button function in order to demonstrate what my project set-out to achieve. Any ideas what chips I would need so I can put forward a hypothetical manufacturing cost? Again, thanks for your help! David. |
| Simple flatulence sound generator circuit? | HarveyH42 | Electronic Projects Design/Ideas/Reviews | 4 | 29th July 2006 05:37 PM |
| SIMPLE OPAMP CIRCUIT. PLS HELP!! | cyprio7 | General Electronics Chat | 4 | 11th April 2005 08:39 PM |
| Simple battery backup auto-switch circuit | ksv | Electronic Projects Design/Ideas/Reviews | 2 | 27th July 2003 10:53 AM |
| Very simple 2sec timing circuit help needed | Meza | Electronic Projects Design/Ideas/Reviews | 9 | 1st April 2003 11:58 PM |
| Please help me with this simple circuit. i cant do it alone! | nate | Electronic Projects Design/Ideas/Reviews | 10 | 23rd December 2002 01:31 PM |
