Old 12th March 2008, 04:27 PM   #1
Default Gated clock pulses
I would like to produce short bursts of clock pulses (about 6 or 8 pulses of a 40KHz clock every tenth of a second). I know how to use a 555 to produce a gate pulse every tenth of a second that is the correct duration, but how would I synchronize the circuit so there is not a transition in the middle of a clock pulse?
DSG is offline
Old 12th March 2008, 05:05 PM   #2
Essentially you don't, and why would it matter?.
Best solution is to program a PIC to do it, an 8 pin PIC is the same size as single 555, and will do it much more accurately with less components.
Presumably you're wanting to generate IR remote pulses?.
Nigel Goodwin is online now
Old 12th March 2008, 05:32 PM   #3
Actually it is for an ultrasonic transmitter. Will a PIC generate accurately timed 40 KHz pulses to properly resonate the transmitter? One cycle makes a difference of about 8.6 mm travel time. I would like a consistent measurement which means I would like a complete pulse at the beginning of the pulse stream.
The other consideration is that the circuit runs off of a 9V battery and I need the battery to last as long as possible. The pulses are not always on, so I need as low of a power draw as possible in its quiescent state.
DSG
DSG is offline
Old 12th March 2008, 09:09 PM   #4
Same thing, IR copied the existing frequency from ultrasonic remotes.
A PIC will generate far MORE accurate 40KHz pulses than a 555.
PIC's are also EXTREMELY low consumption devices, with various included features for further reducing current drain.
Old 12th March 2008, 10:41 PM   #5
PIC it is then. Thanks for the help.
DSG is offline
clock, gated, pulses
Problem with LCD code? spondootre Micro Controllers 15 29th April 2008 10:15 AM
IC`s that can produce spesified number of pulses? biindy Electronic Projects Design/Ideas/Reviews 11 20th October 2005 02:43 PM
counter clock 111 General Electronics Chat 7 3rd July 2005 01:51 AM
Triac Gate Pulses pop General Electronics Chat 0 15th February 2005 11:54 PM
Help me on basketball's game clock and shot clock! syaw_007 Electronic Projects Design/Ideas/Reviews 1 6th September 2004 10:50 PM
