Old 10th March 2008, 10:47 PM   (permalink)
Default IR detection circuit
Ok,
I have 2 sets of 6 infrared LEDs wired in series with a resistor. Using a 555 timer circuit, 1 set of these LEDs outputs a square pulse at 2.5 kHz while the other outputs the pulse at 4 kHz. Both have a 5% tolerance for the output. I need to find a circuit that will be able to read the frequency that is being output through these LEDs. I have tried a few different circuits using black phototransistors but haven't found the correct combination yet.
Any ideas?
UPDATE....I may need to be more specific. In general terms, the emitter is the infrared LEDs outputting the pulse at 2.5 or 4 kHz. I need to find a separate reciever circuit that reads the frequency of the emitter LEDs.
Thank you
micbthom is offline
Old 10th March 2008, 10:53 PM   (permalink)
Please be more specific when you mean "read" the frequency. What kind of output are you expecting? Numerical? Analog voltage? What?
dknguyen is online now
Old 13th March 2008, 02:01 PM   (permalink)
Default Re:
When I say read the frequency, I simply mean that the circuit needs to be able to read the numerical values of 2.5 and 4 kHz and be able to distinguish between the two.
micbthom is offline
Old 13th March 2008, 02:35 PM   (permalink)
I suggest you look into getting an IR receiver, such as the PNAA4614 or PNA4612 (there are plenty others such as the Vishay ones, all can be found on Digikey).
These have built-in circuitry to take an IR signal, amplify it and also get rid of some noise. It'll make your life a whole lot easier, and the range can be pretty good depending upon your emitter LEDs.
If you're going this route, when you buy your IR detector play close attention to the "carrier frequency". This will be some standard value like 38kHz or 56.9 kHz.
You will need another 555 timer, to output that certain carrier frequency into one of the inputs to a NAND gate. To do this, you can use the formula provided in the 555 timer datasheet and calculate the R1, R2 and C1 values you will need. Else you can use a microcontroller to continuously output the carrier frequency (less parts required).
The other input will be from your 555 timer generating your 2.5 and 4 kHz pulses.
Connect the output of the NAND gate to the IR LEDs, and now you'll have your LEDs flashing, through the carrier frequency, at 2.5 and 4kHz.
On the other end, you could simply hook the receiver module signal line to a microcontroller and perhaps using the CCP module; figure out the frequency.
With this, pretty much what ever you send on the emitter side, should be the same that is coming out on the detector side (not counting IR noise, etc.)
One thing to remember, the NAND gate will invert the output, so a high signal will result as a low signal to the microcontroller. Easily fixed in software.
This is a good website for infrared tinkering:
http://www.rentron.com/Infrared_Communication.htm
-Omar
Omar.M is online now
Power Split Converter Circuit n.yashodhar Electronic Projects Design/Ideas/Reviews 0 18th March 2007 09:51 PM
differential op amp circuit? prh Electronic Projects Design/Ideas/Reviews 11 14th December 2006 05:22 PM
start/stop watch circuit bd13 Electronic Projects Design/Ideas/Reviews 2 21st March 2004 04:07 AM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 01:31 AM
On-time delay circuit using LM555 mozikluv Electronic Projects Design/Ideas/Reviews 9 24th October 2003 02:45 AM
