hi guys ...
I am connecting a relay with 555 timer output (pin 3) configured in monostable mode ... when the output come 1, i hear the sound of relay connection, but when the output turns back to 0, i hear a sound (tick tick tick tick ....) as if the relay is connecting and disconnecting ... also the capacitor doesn't discharge and pin 3 voltage still HIGH ... i am using a power supply of 5.5 V and the relay rating is 6VDC ... plz i need help urgently |
Try a ~10k pulldown resistor on the 555 pin 3 to ground.
Thanks IČR ... but what do u mean by pulldown ..? resistor in parallel with the relay ...??
and if yes, how will this solve the problem physically ...? thanks again |
Exactly what I said. A 10 k resistor from pin 3 on the 555 to ground. I can't state it any more clearly than I already did, so I don't understand the source of your confusion. The term "pulldown" means literally what it says:
Its purpose is to pull the output of pin 3 down until it is driven high by the 555. |
IČR ... i got what u mean, but the 10k pulldown resistor didn't fix my problem !!!
eng1 ... i have already tried to place a diode in series with pin 3 and the relay coil to prevent any reverse currents that may be due to the coil, but in this case, the circuit stopped completey, i.e., even the sound of the relay (tick) wasn't heared on starting ... please i still need the help |
See the attached image. The diode accross the coil is the most important.
The diode in series with pin3 produces a voltage drop of about 0.6 V and the voltage that drives the relay could be too low. Last edited by eng1; 10th March 2008 at 08:40 AM. |
What is your actual ON time?... Can you upload your schematic?..
| time delay relay | manz | Electronic Projects Design/Ideas/Reviews | 10 | 17th April 2008 05:56 PM |
| Toggle Switch | eliask08 | General Electronics Chat | 12 | 24th March 2008 04:45 AM |
| Big thermocouple ADC problem | Oznog | General Electronics Chat | 9 | 4th May 2004 08:42 PM |
| MCU controlling relay (or a way to simulate a SPDT relay?) | LiquidKernel | Electronic Projects Design/Ideas/Reviews | 5 | 25th March 2004 03:10 PM |
| Please help! Newbie playing with his furnace - relay help? | egasker | Electronic Projects Design/Ideas/Reviews | 1 | 26th January 2003 05:10 AM |
