i need your help with my project i want to build up an electric kart i got the dc motor from a treadmill that its 1.5 hp and maximum voltage in to 180 vdc i need now to find a dc to dc converter (how to build it or where to buy it) buck- boost converter to get a (12 or 24 or 36 or 48 vdc) input batriies and want to convert it to 180vdc i need to have a dc motor controller but i dunno where to get this stuff and how can i start to design it ? and what controller i need? if you have sites or any good idea or schematic for this both circuit plez help me |
I built an electric go-cart when I was a kid. I used a car starter for the motor. A headlight bright/dim switch for on/off and a car battery.
It saved the brain damage of making a 12 volt to 180 volt converter. I know this did not help. You might get an “inverter”. 12 volts to 110 volts. Then use 4 diodes to rectify to DC. I think you will not need a filter capacitor. The motor will not run at full power but it will run. |
Basically what you're saying is you've got a completely useless motor for the job, and you're like to try and bodge it so you can make it work.
Simple answer, get the correct motor for the job!. Or instead of using car batteries, use fifteen small SLA's in series to give you 180V, and you could distribute these around the chassis to give better handling. |
that 1.5 hp motor is too small for any real performance. Would be better off getting a kiddy electric car. may be cheaper in the long run.
Best solution is a golf cart motor or other dc motor. I recall Popular science or mechanics had artical about using an automotive starting motor. |
Actually electric motors provide more acceleration per hp and petrol engines so 1.5hp might not be as bad as you think. The only problem seems to be the top speed is lower but gearing should be able to fix that.
I agree with Nigel, use fifteen SLAs in series to give 180V, this would be more efficient since you miss out on an extra conversion wich would loose energy. Be careful working with 180V which is hazardous, take the following safety measures into account and you shouldn't have a problem:
Good point!. |
Thanks guys for Your replies
i will start as u said to put fifteen SLAs in series now i have 180 vdc any good ideas ? how to build or choose a controller? for my dc motor ? so i can controll the voltage from 0 vdc to 180vdc i need a good controller design |
What does 15 SLA batteries weigh? What are they rated for?
Since your motor came from a treadmill, there is usually a simple, high-voltage controller that can be plugged into the mains with it or one can be had cheaply. All you need to do is convert your 12 VDC to 110 VAC, as with an inexpensive inverter. The quality of the sine wave is not important, as the controller will rectify it first. John
| Questions leading to small project (Laser Vortex) | Norritt | Electronic Projects Design/Ideas/Reviews | 0 | 17th October 2007 05:47 PM |
| Project | lena2383 | Micro Controllers | 2 | 24th May 2006 06:38 AM |
| Electric Car Project... please help!! | Magna007 | Electronic Projects Design/Ideas/Reviews | 2 | 11th February 2005 03:19 AM |
| Help with RF Xmtr/Recv Project for direction finding | bcollinsks | Electronic Projects Design/Ideas/Reviews | 6 | 2nd March 2004 03:40 AM |
| pls help me on my school project........ | karen | Electronic Projects Design/Ideas/Reviews | 16 | 13th March 2003 09:43 PM |
