Old 8th March 2008, 02:14 AM   (permalink)
Default Dremel
I never really found this information but i thought others might look for it.
I took a picture of a small DREMEL bit kit. This kit comes with 7 bits sizes are:
1/32" EDIT: 1/32 = 0.79375 mm (.8mm)
3/64"
1/16"
5/64"
3/32"
7/64"
1/8"
I would recommend 1/32 for actual PCB pin/part holes. Its actually smaller than Premade PCBs like from radioshack and other places. The 1/8 is good for screw/mount holes. and other sizes can be used for various things.
Heres the picture:
AtomSoft is offline   Reply With Quote
Old 8th March 2008, 08:30 AM   (permalink)
For PCB work I would suggest getting some resharpened 3.2mm shaft diameter tungsten carbide bits as they will last a lot longer than the Dremel bits.
I paid around £15 for a box of 50 assorted bits.
picbits is online now   Reply With Quote
Old 8th March 2008, 10:45 AM   (permalink)
3.2mm is a bit to big for most applications, I normally use a 1mm bit.
Screen name: Aloone_Jonez
As a hobbyist i shop local and have never seen those bits. I just went online to search for them and found most of those are indeed Dremel bits.
Dremel 9901 Tungsten Carbide Cutter
Use for shaping, smoothing and material removal.
Use on hardened steel, stainless steeel, cast iron,
nonferrous metals, fired ceramics, plastics, hardwoods and other
hard materials.
shank size: 3.2mm
working diameter: 3.2mm
Seems like it would indeed be good for PCB work tho. i wouldn't mind buying some if i find them around. Next time im out shopping ill try to see if i can find some.
Old 8th March 2008, 10:56 AM   (permalink)
If you use carbide bits, you will probably need a drill press. HSS takes bending well, but carbide will snap. That said, carbide is way best on fiberglass PCB. For the yellow/orange phenolic PCB, you can get by with HSS. John
jpanhalt is offline   Reply With Quote
Old 8th March 2008, 11:17 AM   (permalink)
Hence why I said shaft diameter
My bits range from 0.1mm up to 6mm with a 3.2mm shaft (shank)
A 3.2mm drill bit would be far too big for most peoples PCB applications
Old 8th March 2008, 11:18 AM   (permalink)
You will definitely need a drill press (or Dremel press) with TC bits - even dropping them on the table snaps them sometimes but for drilling they are incredibly robust.
Old 8th March 2008, 11:23 AM   (permalink)
hard materials.
shank size: 3.2mm
Here you go - this is what I use and I can thoroughly recommend them but you need to use a proper Dremel press with them.
http://worldgift.org/prdrbitset.html
Old 8th March 2008, 09:15 PM   (permalink)
Thanks for that! I have been using the same thing, but have been buying at a tool liquidators, and they have run out.
BeeBop is offline   Reply With Quote
Old 9th March 2008, 09:25 AM   (permalink)
For what you get for your money (50 bits for $18) its worth buying a few boxes. It will keep the average hobbyist going for a few years. I've seen the individual bits being sold for $5+ each so its well worth the money
Old 9th March 2008, 11:06 AM   (permalink)
http://www.ehobbies.com/dre660.html
$4.50 for 4 so that makes about
16 - 1/32 for $18 the difference here is you get all 1/32 and not other sizes you might not use. I would still buy the 50 for $18 as picbits says but its also nice to buy multiple of the same bit without have others you might not use.
Old 9th March 2008, 11:35 AM   (permalink)
3v0
Electronic Goldmine
http://www.goldmine-elec-products.co....asp?dept=1273
has a wide range of resharpened carbide bits for $1 each.
Boxes of 50 in assorted sizes or all the same size can be had for about 50 cents each from various Ebay stores. New and used.
3v0 is offline   Reply With Quote
Rotary Tools dknguyen Chit-Chat 16 15th August 2007 03:50 PM
ATX power supply and Power Dremel jimmyboy General Electronics Chat 1 1st July 2007 02:10 PM
What to use for PCB Drilling ? 3v0 General Electronics Chat 20 1st February 2007 05:57 PM
need help in PCB fabrication syber Electronic Projects Design/Ideas/Reviews 36 29th December 2006 11:10 PM
Cutting PCB's bryan General Electronics Chat 8 10th October 2003 01:40 PM
