Old 7th March 2008, 04:38 AM   #1
Default Help: external siren/output from radar detector?
Wasn't sure exactly how to phrase the title.. but here's the possible scenario's.
1) Looking for a circuit that can go inline w/ the power connector of a radar detector, detect a voltage draw from the detector (indicating it is going off) and then trigger an external siren or even just provide a relay output.
2) Looking for a circuit that can plug in to a 3.5mm audio headphone jack, and provide output as above (see #1)
I would think #1 would be easiest.... anyone?
-Mike
mnapuran is offline
Old 7th March 2008, 10:45 AM   #2
You really need to provide more information.
What type of output does your radar protector provide and at how much current?
The chances are, all you need is a transistor and a relay.
if I know the answer.
Hero999 is offline
Old 7th March 2008, 02:16 PM   #3
Well, going route #1, I'd like this to circuit to be pretty generic. In other words, be able to work with various radar detectors. Obviously, each will have it's own idle current (quite low) but when lights/alarm on the unit goes off, the draw will certainly change. Of course, the detectors work on roughly 10 to 15 volts DC. On the output side of the circuit, it really only needs to be a latching relay or something similar to drive an external 12v siren, light, or whatever.
mnapuran is offline
Old 7th March 2008, 04:58 PM   #4
Have you already got the detector?
I was assuming that you just needed a switch that will connect on to the output of it.
Hero999 is offline
Old 9th March 2008, 07:58 PM   #5
I've seen these circuits before , maybe in "Radio-Electronics" back in the early 80's. Place a resistor(small value) in the power lead and use a comparator to detect the voltage change across the resistor.
Super_voip is offline
Old 10th March 2008, 11:35 AM   #6
That's a good idea.
He might even be able to use a current transformer, the pulsed current generated from the siren might be enough to create an AC signal in the secondrary.
Hero999 is offline
detector, external, radar, siren or output
Radar motion detector VictorPS General Electronics Chat 6 4th July 2006 11:04 AM
Anyone know how to set off a police radar detector??? machavelli Electronic Projects Design/Ideas/Reviews 6 25th April 2005 07:33 AM
remote led display for radar detector walt steele Electronic Projects Design/Ideas/Reviews 5 16th August 2004 11:14 AM
Radar detector ElManu Electronic Projects Design/Ideas/Reviews 0 11th September 2003 10:01 PM
Device to Trigger Radar Detector AuctionHugh Electronic Projects Design/Ideas/Reviews 2 26th August 2003 09:17 PM
