Old 6th March 2008, 04:33 PM   (permalink)
Default Sound record chip and amplifier?
Does anyone know of a suitable sound record chip and associated circuitry to drive a speaker loud enough to be heard in a car?
The chip should have enough storage capacity for about 10 seconds of audio, and preferably be able to switch between 4 messages selected by a 16F877 or some similar kind of PIC
karenhornby is offline
Old 7th March 2008, 12:24 AM   (permalink)
Radio shack ISD1000A, just the IC, 20 sec up to 160 segments, pretty basic addressing. Might work for you. I've played with this chip but not with a PIC.
G_Man is offline
Old 7th March 2008, 02:33 AM   (permalink)
Hi karenhornby,
that chip is easy to use, but you won't get around an extra amplifier for it. Use an LM386 which is also easy to use.
Boncuk
Boncuk is offline
Old 7th March 2008, 02:36 AM   (permalink)
I imagine one of the messages: "Please pull the key for later use"
Another simple way: Drink at least 1/2 gallon of milk daily. It's good against "Maroditis"
Boncuk is offline
Old 7th March 2008, 11:54 AM   (permalink)
The LM386 isn't loud enough to be heard in a car when it's doing 70mph down the motorway.
Use a TDA7052 which puts out much more power.
Screen name: Aloone_Jonez
Hero999 is offline
Old 11th March 2008, 12:22 PM   (permalink)
I suggested that amplifier assuming that most of the messages will be used when the engine is idle, like "fasten seat belt" or after engine shutdown "take your key along"
Boncuk is offline
Old 11th March 2008, 12:56 PM   (permalink)
LOL nice suggestions for messages
but it will actually be used as part of my Veg Oil conversion for my car, when the engine IS running or just after its been turned off, to give me an audible warning to flush the oil out of the fuel pump before turning off the engine, and providing that section works ok, I may get it to announce what fuel it is using as well as just showing which fuel on the LCD display
Old 12th March 2008, 01:28 AM   (permalink)
Hi Karen,
don't care. I'm living on the sunny side of the globe and so is my mood.
However, if the LM386 is too weak you might try an LM380 with 2.5W output power. Considering the low power necessary to listen to the radio (about 250 to 500mW) that output should do, even if your engine sounds like hammer and nails. (like all Izusu cars).
There are two versions of the LM380: 8 pin DIP and 14 pin DIP. I suggest to use the latter type. It has six extra GND pins for better cooling. Plan for at least 4 square inches of cooling surface on the solder side.
If you are in need of a circuit PCB just give me a note. I've made one with any available space as cooling pad. To increase cooling you might add an IC-heatsink.
Kind regards
Hans
Boncuk is offline
Old 16th March 2008, 09:28 AM   (permalink)
ISD25120 Voice Record/Playback device has 120 seconds of time that can be broken down into six hundred 200 millisecond messages which can be selected by the microcontroller of your choice. They also have the ISD1420P which has 20 seconds total time and the ISD2560P which has 60 seconds. These are available from www.jameco.com for $12.95 USD. They have a built in amplifier but I would recommend using amplified computer speakers to get the sound volumes for in the car.
I am interested in your vegetable oil car information!!
Also, I have spent much time and money trying to use microcontrollers and just recently I have heard of the PICAXE microcontrollers. They are a specially made PIC Microcontroller. They are so easy to use that I had programs up and running on the free programmer even before I had my chips.
The interface to the computer is a standard three wire serial connection. A serial cable with flying leads on the one end and a couple of resistors is all you need to send the program to it. Microcontroller prices range from $3.50 for the 8 pin 08m version to $11.50 for the 40 pin 40X1 version in Canada. www.hvwtech.com
All the info that you need is available from www.rev-ed.co.uk
Hope this is helpful.
Carl
C.Ray1959 is offline
Old 16th March 2008, 09:58 AM   (permalink)
Carl
Need Help in Loop Antenna Building Harros Electronic Projects Design/Ideas/Reviews 119 27th March 2008 03:25 PM
power amplifier chip stk0039 baddad General Electronics Chat 4 20th October 2004 01:24 AM
Audio Amplifier Designing Project silverferro Electronic Projects Design/Ideas/Reviews 3 26th August 2004 11:05 AM
Ultrasensitive Amplifier Chip thephoenix Electronic Projects Design/Ideas/Reviews 1 14th October 2003 07:38 PM
Bedroom Sound System Paprika Electronic Projects Design/Ideas/Reviews 11 21st February 2003 10:14 AM
