| Hey, I just saw this page. It is great if you want make your own lab power supply: http://www.bigedu.org/m6_crafts/elec...ply/main3.html | |
| I'm about to start building one of these, but with a +/-9v regulated supply. | |
| How are you planning to gey the +/-9V out? Are you going to add a pair of LM317/337s or a switching regulator on the output? Are you going to modify the internal circuit so it outputs +/-9V?
| I plan to use a 7809 and 7909 with a SPDT switch on the +/-12V output, to produce 9/12 volt interchangably (but using different output sockets), and add a slow-blow 1A fuse to the 0v output. | |
| Fusing the 0V line is never a good idea. Suppose the +12V line shorts to the -12V line? The fuse won't blow. The 0V rail is internally bonded to earth ground in the power supply. If the output shorts to the metal case or another earthed object like a metal radiator the fuse won't blow. Put fusses on all the outputs you intend to use. The power supply should be protected against short circuit anyway but you never can rely one it.
| Ah, I hadn't considered internal shorts! Doh! | |
| That is such a badly built power supply. Twisting the wires then bunging a bit of insulating tape over them is just asking for trouble. He doesn't appear to include any load on the 5v or 12v rails which could also lead to instability with PC power supplies under low current conditions. | |
| I'd just like to point out I'm not using that site, but my 1st post merely fitted in here. | |
| can is follow the link can add circuit part fines the trend ? , | |
| Got a new EVBoard How do i supply power to it? | cubdh23 | Micro Controllers | 2 | 3rd August 2007 10:39 AM |
| power supply question | raphaelriv | General Electronics Chat | 3 | 21st May 2007 09:33 PM |
| Capacitor based power supply | dadwhiskers | Electronic Projects Design/Ideas/Reviews | 6 | 28th April 2007 09:42 PM |
| Power Supply for a project to be powered within an Auto? | hexibot43 | General Electronics Chat | 16 | 8th September 2005 03:36 PM |
| Power supply/ current supply design | inkedallusion | Electronic Projects Design/Ideas/Reviews | 1 | 17th December 2002 02:10 AM |
