Old 6th March 2008, 10:10 AM   (permalink)
Default Power Measuring Methods
Hi
I'm working on a design project that requires the measurement of power usage in a home. The PC is used to display a log of this. What I would really appreciate is if someone could give me a brief idea of how many methods there are of actually measuring the power.
I found out that one could use a current transducer at the mains or count the number of times the meter needle spins. Which of these will be easier to implement? And what are the drawbacks?
Suds is offline
Old 6th March 2008, 10:13 AM   (permalink)
Assuming the idea is to monitor your actual costs?, then the meter spinning is the only way to do it - that way you're actually monitoring what you're going to get charged.
If you want to monitor power consumption?, check EPE, they did a two channel PIC based monitor the other year, which used a special monitoring and multipying chip.
Old 6th March 2008, 11:24 AM   (permalink)
Thanks Nigel, how can I get hold of EPE?
Suds is offline
Old 6th March 2008, 11:29 AM   (permalink)
It's a UK magazine http://www.epemag.co.uk/
Old 6th March 2008, 01:55 PM   (permalink)
EPE has forums:
http://www.chatzones.co.uk/cgi-bin/discus/discus.cgi
Bob Scott is offline
Old 7th March 2008, 05:53 AM   (permalink)
Thanks Nigel and Scott
Suds is offline
computer controlled power switch Michael Daly Electronic Projects Design/Ideas/Reviews 2 25th June 2007 07:14 PM
Draining capacitors on power supply hfireworks Electronic Projects Design/Ideas/Reviews 24 27th April 2007 03:03 AM
Power Split Converter Circuit n.yashodhar Electronic Projects Design/Ideas/Reviews 0 18th March 2007 09:51 PM
[b]Power supply to a sensitive measuring device[/b] min_anna Electronic Projects Design/Ideas/Reviews 1 13th April 2004 11:59 AM
Power supply: Fusing to protect circuit Johnson777717 Electronic Projects Design/Ideas/Reviews 4 10th April 2004 03:19 AM
