I have been playing with some different OptoIsolated components (OptoTransistor, OptoTriac) as a way of providing isolation between the trigger section, and the output section of some different circuits, but it seems that 2 separate power supplies would be needed to truly keep the sections isolated. Is this indeed the case, or is there a way that one power supply (battery or plug-in) be used and still allow full isolation?
Well technically you need two power supplies anyway.
You could use a pulse transformer to trigger a triac but you still need anther power supply (the voltage you're switching). You can buy high quality expensive regulated isolated power supplies or make you're own unregulated isolated power from a transformer.
Hero999 - Thanks, when I was drawing the circuit, and using a 9 volt battery for the trigger side, I sort of thought this was the case in needing a separate battery for each output side if I wanted to maintain true isolation.
Michael |
| Got a new EVBoard How do i supply power to it? | cubdh23 | Micro Controllers | 2 | 3rd August 2007 09:39 AM |
| Draining capacitors on power supply | hfireworks | Electronic Projects Design/Ideas/Reviews | 24 | 27th April 2007 02:03 AM |
| Using a computer power supply WITHOUT a computer? | grrr_arrghh | General Electronics Chat | 13 | 4th April 2007 12:15 AM |
| 24v DC Power Supply (Help & Information Wanted Urgently) | ampthetex | Electronic Projects Design/Ideas/Reviews | 5 | 17th November 2006 12:44 PM |
| Power Supply for a project to be powered within an Auto? | hexibot43 | General Electronics Chat | 16 | 8th September 2005 02:35 PM |
