| Do you know how much voltage you get from the speaker when you "brush" it? I tapped (not brushed) a little oval 8 ohm speaker, and got output pulses of ~0.1V - 0.4V, depending on how hard I tapped it. How and why are you touching (you said tapped, then you changed to brushed) the speaker? | |
| Just kind of a light brush, it's a poly spealer from a pr of headphones like 32ohm really light plastic, real soft and crunchy. I read about ~.2 volts on this one with a light brushing, enough to make it crunch just a little. brush more than tap but a light tap would be about the same. Last edited by G_Man; 5th March 2008 at 10:59 PM. | |
| Does it need to require the same number of touches before each trigger, or do you want it to be a function of how hard you touch it and/or whether you tap it or brush it? In other words, do you want the circuit to basically "count" the number of touches? What is the maximum and minimum time between successive touches? | |
| No, counting isn't necessary. The brushing of the poly speaker will be a constant,It will always be the same. but being able to adjust the time between when the brushing starts and the 555 fires is a must. For example, During "Set Up" I can adjust the time it takes when I start the brushing of the speaker and when the 555 fires, and change it if necessary. Maybe giving between 1-15 minutes between when the brushing starts and the timer fires. | |
| Hee, hee. I am a dirty old fondler!
| | (permalink) | ||
Another question: What might be the minimum and maximum number tof touches required for triggering, i.e., you want it adjustable, but over what range? | |||
| Once the brushing starts, it will continue at a constant, it would be milliseconds between brushes. Imagine brushing your finger back and forth on the speaker. Maybe 500 brushes to start, like one minute, going up from there to 15 minutes before the timer fires. | |
| I am an audio guy but I have never fondled a speaker. Most girls can't speak anymore after being fondled 500 times in one minute. I got slapped once.
| Aww, c'mon we all know you have fondled at least one speaker. | |
| One more thing that might clarify things, I don't want any stray brushing to do anything only trigger the timer when it's sustained for a few minutes, hence charging the cap idea. George | |
If the counter does time out (time adjustable 1-15 minutes), it stops the clock but does not reset itself, effectively latching the counter output until the brushing stops. You can take the counter output and trigger a timer, or whatever. It might not work with your speaker without some tweaking, because I don't know what the actual signal out of it looks like. | ||
| I thinkI might have most if not all of that sitting on my desk right now. Will a CD4017BCN work for the counter? I also have a LM339 quad comparator. That sounds like it'll work. Last edited by G_Man; 6th March 2008 at 06:30 AM. | |
You also need a CMOS 555 and an op amp such as TL071 or TL072, and a handful of resistors, capacitors, diodes, etc. Last edited by Roff; 6th March 2008 at 06:34 AM. | ||
| Uni Project Advice | 2-tone | Electronic Projects Design/Ideas/Reviews | 7 | 18th October 2007 01:11 AM |
| PIC home controller project | teracon | Micro Controllers | 1 | 25th December 2005 04:36 PM |
| need help on home security project | crazytwism | Electronic Projects Design/Ideas/Reviews | 3 | 21st March 2005 09:26 AM |
| home project help | simple&cheap | Micro Controllers | 2 | 10th March 2004 09:43 AM |
| RGB LED Home lighting project | BrianK | Electronic Projects Design/Ideas/Reviews | 6 | 9th November 2003 08:21 PM |
