I want to start a project to pulse coils of different types & study the effects of the magnetic waves produced. I am a novice at electronics & need some help with things. Please excuse my ignorance with this but i want to give it a go.
I have found a Circuit on the Net --SEE ATTACHMENT & DESCRIPTION BELOW---that will handle high Voltage & Amps & i want to adapt this to my needs.
I can't read the parts listed on the Schematic on my computer as they look all jumbled up & hard to read, could somebody with suitable knowledge help out with this & clarify the schematic & a parts listing & numbers, values etc to suit.
As i understand it Amps are the key to producing powerful coils rather than Voltage--Please advise if this is not so or both can create the same results independantly.
If this is the case i would like to power this circuit from a 12v DC 30-50Amp power source & would like some advice as to what components i should use on this circuit.
If not i can run the circuit from a 240v DC 20 to 30Amp power source & advise again on components would be very helpful.
From what i can see & read the circuit needs a controlled input pulse of 0-5V dc & two 12V dc inputs as well as the main voltage souce marked HV, is this correct?
I would like to have a "variable" pulse generator or circuit as the controlled input pulse if one exists, please advise once again.
Thank You
Circuit Desciption Below:
Fast rise-time high-voltage pulses have many uses ranging from EMC testing to device characterization. The simple, low-cost circuit described here deals with the latter. Its able to generate 0- to 1000-V pulses with currents up to 50 A, and a rise time of 100 ns for 800 V/30 A. The output can withstand short circuits, and capacitive and inductive loads. Pulse length and repetition rate are determined by an optically isolated TTL-input signal. Commercial equipment like pulse/function generators or a PC can be connected to this input. The pulses amplitude is set by the HV supply; a low-cost photomultiplier-type supply (0, 5 ..5 mA) can be used when repetition rates are below 20 Hz.
The circuit operates as follows: when applying the HV supply, C1 is charged up to a voltage HV via R1 and D1 (see the figure). A 0-V control signal keeps the PowerFET Q1 in the off state. A 5-V signal on the control input operates the driver IC2, from which a 12-V signal is presented on the gate of the PowerFET Q1, bringing it into conductance. The output of the circuit becomes −HV volts as the negative terminal of C1 is now grounded. The pulse ends by making the control signal 0 V. Useful pulse length is limited by he voltage drop during the pulse (caused by discharging C1) and by the 100-”s/64-A save limit of the PowerFET. For the values shown, the circuit voltage drop is 10 V for a 1-”s, 10-A pulse.
The short-circuit and overload protection is based on R1. When the output current is rising, the effective gate-source voltage of the Power-FET diminishes, enlarging the FET resistance. With the given 0.1-Ω value, the output current is limited to 50 A. In a short-circuit situation, capacitor C1 can be fully (and safely) discharged in the PowerFET. Reverse voltages caused by inductive loads are eliminated by D1. When the circuit isnt operating, R14 discharges C1 for safety reasons.
Circuit layout is very importanta groundplane is needed to keep inductance low. C1 must be a low-inductance pulse capacitor. Even the FET driver IC2 needs a low-inductance layout and decoupling. During the leading-edge gate currents, up to 2 A are needed to charge the FET input capacitance. Resistors R1 and R2 have to be made of at least 10 paralleled discretes to get a low series inductance. R4 and C3 compensate for the remaining inductance in R2 (the value of C3 can be changed for this). C2, R5, R6, and R7 form a snubber network to protect the FET against voltage spikes. The values for the voltage and current monitor levels are given for a 50-Ω load.
Higher currents can be obtained by duplicating the IC2-Q1-R1 stage and connecting them in parallel. R1 helps to equalize the current for each stage. A 100-A pulser has been successfully built in this manner.
