Hi, I'm hoping some here can help me with my laptop power adapter. It's supposed to be putting out 19v to power my lappy, but the other day it just wouldn't work. So I checked it with my volt meter an it gave me a rating of 12v
I assume that you have measured the voltage with no load, i.e. with the laptop disconnected.
If so, it is certainly dead. Laptop power supplies are difficult and dangerous to fix. It may be possible to save a few dollars by buying a generic supply and fitting the cord from your broken one. However, many manufacturers (including Dell) have special identifying chips in the power supplies, so you can't just supply the correct voltage. This is real pain if it is combined with a badly designed connector, like Dell use. |
Yes, you are right, it was measured with no load. Thanks for the quick reply, though it is sad news. It was a Toshiba btw
Come to think of it IČR, neither have I lol
Some Dell power supplies are connected with a three-core cable. Two cores provide the power and one connects to an identifying chip. I think it is a Maxim 1-wire device.
The laptop will not charge the battery unless it recognises the chip. This happens quite often because of the lousy connectors. I get a warning on screen that I should connect the correct power supply. That only happens if there is power to the power supply, so the laptop certainly can recognise power and the correct power supply separately. |
Simply don't buy a Dell laptop.
Choose a laptop with a standard DC connector.
| Power Supply Question | brittam | Electronic Projects Design/Ideas/Reviews | 1 | 12th July 2007 08:54 PM |
| ATX power supply and Power Dremel | jimmyboy | General Electronics Chat | 1 | 1st July 2007 02:10 PM |
| computer controlled power switch | Michael Daly | Electronic Projects Design/Ideas/Reviews | 2 | 25th June 2007 06:14 PM |
| Ultra low power power supply | steevke | Electronic Projects Design/Ideas/Reviews | 1 | 3rd February 2006 03:46 AM |
| Power Supply for a project to be powered within an Auto? | hexibot43 | General Electronics Chat | 16 | 8th September 2005 02:35 PM |
