| Could anyone tell me how to make an AM receiver? I just need one frequency. | |
I didn't mean any offense, it's just that you weren't very specific, and there are so many different ways to do this for different results. There are several that require no battery at all. If you have a weak signal, you may want to add an amplifier stage (lots of options here). Output... speakers need an amp, some earphones... | ||
| Nearly 100 years ago people made crystal radios to pickup the only AM radio station in their country. They used a very long insulated antenna and an earth ground.Today there are many AM radio stations in each city. An old crystal radio has only a single tuned circuit so it will pickup most of them at the same time. Besides, the high frequency audio response of an AM radio is horrible. Use an FM radio for good sound.
I made a crystal radio about 105 years ago. It sounded horrible. I recently tuned my car radio across the AM band to try to find out the score. There were hundreds of AM stations. Luckily the radio has many tuned circuits for good selectivity. It also sounded horrible.
| Last month I finally figured out how to get the dash open and remove the radio from my Explorer. It didn't work, because nothing was hooked up. Plugged everything in, and only got cassette and AM. Lots of AM stations, mostly in spanish though. | |
| I only need it to be at 1MHz... I just need it tuned to that freq... | |
| Just built one of the crystal radio designs I linked you to in my previous post, tune it to 1MHz and leave well alone.
| I found this while surfing.... This is a compact three transistor, regenerative receiver with fixed feedback. It is similar in principle to the ZN414 radio IC which is now replaced by the MK484. The design is simple and sensitivity and selectivity of the receiver are good. All general purpose transistors should work in this circuit, I used three BC549 transistors in my prototype. The tuned circuit is designed for medium wave, but the circuit will work up to much higher frequencies if a different tuning coil and capacitor are used. I used a ferrite rod and tuning capacitor from an old radio which tuned from approximately 550 - 1600kHz. Q1 and Q2 form a compund transistor pair featuring high gain and very high input impedance. This is necessary so as not to unduly load the tank circuit. Q1 operates in emitter follower, Q2 common emitter, self stabilizing bias is via the 120k resistor and the tuning coil. The 120k resistor provides regenerative feedback,between Q2 output and the tank circuit input and its value affects the overall performance of the whole circuit. Too much feedback and the circuit will become unstable producing a "howling sound". Insufficient feedback and the receiver becomes "deaf". If the circuit oscillates,then R1's value may be decreased; try 68k. If there is a lack of sensitivity, then try increasing R1 to around 150k. R1 could also be replaced by a fixed resisor say 33k and a preset resistor of 100k. This will give adjustment of sensitivity and selectivity of the receiver. Transistor Q3 has a dual purpose; it performs demodulation of the RF carrier whilst at the same time, amplifying the audio signal. Audio level varies on the strength of the received station but I had typically 10-40 mV. This will directly drive high impedance headphones or can be fed into a suitable amplifier. | |
Please post the link where you found this. | ||
| That's trus, the 100nF capacitor will shunt all the RF to 0V. The transistor might do some detection because it's non-linear and might distort the signal enough.
| I think it was made on a breadboard and the sloppy wiring coupled the signal from the output back to the input in phase.
| IR LED Receiver Question??? | shaneshane1 | General Electronics Chat | 3 | 23rd November 2007 11:44 AM |
| ir receiver question | shaneshane1 | General Electronics Chat | 19 | 21st February 2007 05:06 AM |
| Simple AM receiver | crivoli | Electronic Projects Design/Ideas/Reviews | 11 | 24th May 2006 01:48 PM |
| Question on a modem receiver using MC13135 | nickagian | General Electronics Chat | 3 | 20th December 2005 09:12 AM |
| If anyone is looking for an FM receiver to make..please read | brancambre500 | General Electronics Chat | 2 | 21st January 2003 09:20 PM |
