Old 1st March 2008, 10:53 AM   #1
Default 230 Volts LED night light project
230 Volts LED night light project.
Here is an addition to the popular LED indicator lights.
I have made some LED lamps as well for 230 Volts. I used an old base from a discarded compact fluorescent lamp. It got the B22 socket and has a wider base which is excellent for the LED project. I use them as night lights in my house so I don’t have to switch lights on and wake myself up too much when going to the loo.
Of course an Edison E27 base can be used as well and for 110 Volts use 2 *8k2 or 10 k Ohms resistors in series.
3552 The B 22 base with 4 * 8k2 ohms , 1 Watt resistors and the 1 N4007 diode.
3553 Side view of B 22 base.
3554 9 LED’s glued with araldite to a transparant pvc base. (8 blue, 1 green).
3559 Section of LED’s under test. I find it very handy to test for correct polarity when a string of LED’s is soldered. It saves a lot of messing about later on when things don’t work when a LED is put in the wrong way around. I use a 12 Volt power supply limited to 10 mA, so I can’t blow up any LED’s.
3561 Test run at 230 Volts. Current is only 3.17 mA.
3565 LED lamp going in my lounge.
3566 LED lamp from different angle.
Regards, Raymond
Keen to hear ideas or see photo’s from other forum members who have built some LED lamps.
230 Volts LED night light project-dsc03552.jpg   230 Volts LED night light project-dsc03553.jpg   230 Volts LED night light project-dsc03554.jpg   230 Volts LED night light project-dsc03559.jpg   230 Volts LED night light project-dsc03561.jpg
230 Volts LED night light project-dsc03565.jpg   230 Volts LED night light project-dsc03566.jpg
Please don't sent me private messages, I will not answer them.
The questions asked can be discussed in the open forums.
http://www.youtube.com/user/RODALCO2007 some interesting electrical stuff to watch.
RODALCO is offline
Old 1st March 2008, 01:35 PM   #2
Why use blue, it destroys your night vision?
Use red because the rods don't respond to it which enables you to stay dark adapted.
if I know the answer.
Hero999 is offline
Old 1st March 2008, 11:38 PM   #3
Thanks for the tip Hero999. I like blue that's why it choose it.
You got a good point there, thanks.
Any colour led may be used, it's up to the user.
RODALCO is offline
Old 2nd March 2008, 04:43 AM   #4
good to see u back in LED action "RODALCO"
and thanks for the details.
during these days i come across some data where they said one can drive the LED much brighter using PWM method.
say 20ma is the suitable current for LED,if we drive them at 50ma it will generate more brightness along with lot of heat eventually it will burn out.
in PWM mode the current will keep switching.giving the time for LED to cool down.
have u done any research over this LED driving method.
i know iam going from 220v AC to PWM dc(off topic),but its related to to LED
student1616 is offline
Old 2nd March 2008, 04:55 AM   #5
Driving an LED past peak IsubF works just fine; you need only ensure the average delivered power doesn't exceed the maximum rated power dissipation of the device over a very short period of time. Note that overdriving an LED in this manner will likely cause its peak wavelength emission to shift up slightly. This characteristic has been employed deliberately, for example to get blue LEDs to emit in the UV.
I²R is offline
Old 2nd March 2008, 11:31 AM   #6
The PWM thing only works on some red and infrared LEDs, modern blue LEDs actually tend to be more efficient at lower currents.
The UV trick only works on a specific kind of blue LED that's no longer made.
Hero999 is offline
Old 2nd March 2008, 02:43 PM   #7
so can a 555 based PWM generator do that job?
http://www.reuk.co.uk/LED-Dimmer-Circuit.htm
this circuit is ment for LED dimming,but can we use it for over driving.
and say if i use good heat sink along with LED's,how much is the possibility for over driving.
Old 2nd March 2008, 03:06 PM   #8
A 555 timer PWM dimmer isn't really compatable with this kind of power supply as it is at the moment. To make it work with a 555 you need to add a zener diode and a filter capacitor to give a stable DC power supply.
I wouldn't bother as I don't see the point in PWM unless you do want to change the brightness.
Hero999 is offline
Old 2nd March 2008, 03:37 PM   #9
why iam running behind this PWM-over driving led is,
i saw a product made by the local company in my area.they make LED lights.they are so bright and nice that i amazed.i did some inquiry abt that product.and came to know that they are using same LED's that iam using for my experiments.my friend,(who work in that company) said that they are using some sort of driving circuit(involving flat heat sinks) to avoid the more number of LEDs to get more brightness.
then i had this PWM'ing in my mind.
Old 2nd March 2008, 07:05 PM   #10
Originally Posted by Hero999
The PWM thing only works on some red and infrared LEDsV trick only works on a specific kind of blue LED that's no longer made.
Not quite true. Nearly any LED can be driven to a higher luminance than designed for by PWM overdriving; although, as you noted, the efficiency may suffer as a result. Whether the increase in light output is visually noticeable or not depends on the LED and its emitted spectrum. And all LEDs exhibit some degree of spectral shift when driven at other than nominal current (both under- and over-driving). Whether the shift is towards the blue or red depends not only on the relative magnitude of the driving current, but also on the specific chemistry. Many LEDs will blueshift when overdriven, but some will redshift instead. There isn't much need anymore to drive a blue LED to emit UV, what with the ready availability of UV LEDs with peak emissions as low as 360 nm (and even lower if you're willing to pay for it.) If you can manage to wade through the technical jargon, the following article addresses the spectrum shift issue:
http://www.lrc.rpi.edu/programs/soli...PIE6337-17.pdf
I²R is offline
Old 2nd March 2008, 07:26 PM   #11
I'm not disputing that LEDs will give more light when pulsed at higher currents. It's just not worth if because the efficiency invariably suffers and the response of the human eye acts like a low pass filter so it won't make any difference to the overall brightness. For example PWMing an LED at 50% duty cycle with double the current might make it twice as bright but it won't look any brighter.
PWMing is only worth it if the LED does work better at higher currents or it is used for transmitting information as the range may more than double without using any extra power.
Hero999 is offline
Old 2nd March 2008, 10:37 PM   #12
I agree with Hero.
My Ultrabright LED chaser projects use PWM to dim the LEDs. When the duty-cyle is 20% and less then the LEDs are dimmed. When the duty-cycle is 1/1000 then they are very dim. The peak current is exactly as high as when they are bright.
audioguru is offline
Old 3rd March 2008, 12:43 AM   #13
Uh, yes, it would be. PWM doesn't change the applied voltage during the "on" time and therefor doesn't affect the current draw.
I²R is offline
Old 19th March 2009, 01:13 PM   #14
Its an amazing project,as it saves energy consumption.
but i would rather suggest to use white LED's,as they are more light efficient.
ajaypatil_1987 is offline
Old 19th March 2009, 06:38 PM   #15
Default Leds
Nice Project RODALCO Thanks for posting. I like Blue Led's also.
(All Roads lead to Rome)
power58 is offline
230, led, light, night, project, volts
Fading Light Project neiltdi Electronic Projects Design/Ideas/Reviews 6 6th September 2009 01:05 PM
Project: Strobe Light ElectroMaster Electronic Projects 19 2nd November 2008 01:38 AM
Project: Night Buzzer zachtheterrible Electronic Projects 67 16th July 2008 05:33 PM
First Project (Air Mouse/Pc Light Gun)(&First Post) Sim Electronic Projects Design/Ideas/Reviews 9 8th April 2004 04:02 AM
Variation on the Light Bulb Sequencer Project AZDean Electronic Projects Design/Ideas/Reviews 7 20th February 2004 05:22 PM
