2)The coil of a 300V moving iron voltmeter has a resistance of 500Ω and an
inductance of 0.8H. The instrument reads correctly at 50 Hz AC supply and takes 100-mA at full scale deflection. What is the percentage error in the instrument reading when it is connected to 200VDC supply? 3)A 250V moving-iron voltmeter takes a current of 0.1A when it is connected to a 250VDC supply. The coil has an inductance of 0.5H. Determine the error in the reading when the meter is connected to a 250V, 50Hz AC supply, assuming that the voltmeter reads correctly at DC supply. hi.. i am new member i don know is it correct to post it here if is wrong pls tell me.. thx alot... ok.. up there is the questions.. i ady have the solution i will upload it pls kindly try to see for me... y this two is almost the similiar question but question 2 is using V,voltage to find while question 3 is using I, current to find.. thx for the help... |
If we do your homework for you what will you learn?
zzz juz a simple question la even the solution i d got juz don understand wan to ask pls
i mean i already have the solution juz have some doubt so post it up to ask~
Then tell us your answers, that might start a discussion.
i d attach on it.. the image inside got solution for question 2 and 3~ see nicely,... thanks
where is nigel? usually he would put a stop to that kind of jargon. haven't seen any replies from him in a while.
Your images are 2500 x 3500 pixels. You'll have to wait till someone gets a high enough resolution screen so they will fit.
I only checked your first answer and it looks fine to me. The only error I can see is you can't separate the reactance into w²L², it has to be (wL)². You state the equation wrong but have done the calculations correctly.
Mike. |
but my doubt is y the first question is using V,voltage to calculate the error while in question 2 is in I, current, ampere to calculate the error. thanks for the help.. |
Mike. |
| Capacitor Charge/Discharge question | ThermalRunaway | General Electronics Chat | 25 | 12th August 2008 04:48 PM |
| A whole lot of question (z80 related, along with some others) | Marks256 | General Electronics Chat | 35 | 8th February 2008 10:00 PM |
| A/D Converter related question | appleseed | Electronic Projects Design/Ideas/Reviews | 32 | 4th September 2006 11:06 AM |
| Mobile phone related question | waynefeltham | Electronic Projects Design/Ideas/Reviews | 16 | 22nd September 2003 09:05 AM |
