| can aynone give me simple diagram for making wireless speakers | |
| wireless speakers? What i get is that you want to transmit an audio signal to a remote speaker! If that is it, Then here are the module which i used. http://www.parallax.com/Store/Access...%2cProductName well its it very easy to use, check out its datasheet. If you want to make this module your self, check out this http://www.linxtechnologies.com/Prod...ation-Modules/
__________________ Khizer Naeem Mughal IIUI | |
| Hi, Those modules recommended don't have the bandwidth to cope with audio, perhaps compressed telephone quality audio but certianly no where near enough for Hi-fi. Also, they are digital, so you would be forced into encoding analogue audio to digital, then decoding it...real hassle. Ultimately you must decide range, and quality. And also power! Even wireless speakers need power, batteries will only last so long and have limited power. I would suggest looking for an analogue FM circuit, running at a license free band. I believe the standard FM 88Mhz-108Mhz has been released for ultra low range systems. (like those FM transmitters for iPods). Not the best quality in the world, and you could get interference, but its probably the 'simplest' way for DIY. The second approach I have experience in, is digital. Its expensive, complicated, but it can allow you to get CD-quality audio over a decent range, without dropouts. Considering it is for qireless speakers, latency will not be an issue (if they are the only speakers producing sound) so you could consider compression techniques so that it uses a lower bandwidth...and so allows you to use 'off the shelf' wireless modules, Would still require a good 500kb/s - 1Mb/s though. As I said, a simple analogue system would probably suffice for your needs. Google 'Fm transmitter circuit' and I'm sure you'll find plenty of schematics. Two different transmitters, for each channel, tuned to different frequencies, and then in each speaker you could have a cheap FM radio, with a power amp. Beware of intreference. Blueteeth
__________________ Inconsistency is the key to flexibility! | |
| please give me the circuit for making wirless speaker | |
| please help me and give me the reply for making the wireless circuit | |
Thats all I can say right now. Blueteeth
__________________ Inconsistency is the key to flexibility! | ||
| i have a 5.1 channel home theatre in the home and i want to make it wireless can any one help me please with circuit diagram yo make | |
| Buy a stereo FM transmitter and a stereo FM radio.
| Buy a wireless 5.1 system. It would be much more cost effective.
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. | |
| Wireless network - help | whiz115 | General Electronics Chat | 5 | 13th December 2007 05:23 AM |
| I need help with a set of speakers, please! | Mormoran | General Electronics Chat | 24 | 2nd October 2007 12:37 AM |
| wireless speakers | Bryce | Electronic Projects Design/Ideas/Reviews | 2 | 16th February 2006 04:47 AM |
| Controlling robot from PC, using wireless LAN and USB camera | keops_777 | Robotics Chat | 10 | 2nd September 2004 07:30 PM |
| hooking speakers up to tv | tyler | General Electronics Chat | 7 | 25th July 2003 04:50 AM |
