Old 27th February 2008, 09:16 PM   (permalink)
Default Metal Detector Oscillator/Mixer ??
I have designed a circuit with two oscillators that need to be mixed. I know the low pass filter of the circuit attached works properly. I wanted the oscialltors to run at 100Khz. That isn't a must. The osciallator and mixer circuit isn't operating properly.
excetara2 is offline
Old 27th February 2008, 09:58 PM   (permalink)
Hi Excetara2,
You gonna have to redesign your oscillators because those 0.1 µ
base-emitter caps short the signals to ground.
And . . . both oscillator signals aren't mixed but added therefore the
output of the low-pass filter will always be zero.
on1aag.
on1aag is offline
Old 27th February 2008, 10:26 PM   (permalink)
Thanks for the help. I wasn't sure how to implement a mixer on the back eng of this. Any ideas.
Old 27th February 2008, 10:38 PM   (permalink)
Those oscillators are Colpitts, and there is a voltage (about 100 mV) across the 0.1uF caps. [edit]If you want more output on the bases, make the collector and base resistors more equal. (To maintain frequency, you'll have to change the values.)[\edit]
Point about the mixing is well taken; you need a mixer to combine the two signals. [edit] Look for single balanced mixers, you can do it with two or three transistors.[\edit]
mneary is offline
Old 28th February 2008, 12:08 AM   (permalink)
Got the mixer curcuit working and the low pass filter. The osciallators don't seem to work or they only work for the first 5ms or so. Any advice. Is there any other designs of oscillators?
Old 28th February 2008, 12:27 AM   (permalink)
Hi Excetara,
Try this one . . .
on1aag.
on1aag is offline
Old 28th February 2008, 12:39 AM   (permalink)
I'll give that a try. Realized it wasn't the osciallator I think that is the problem but that Pspice doesn't read the oscialltion properly. The oscialltion looks as it is attenuated. Then if you change step size and slower time. You can see the oscialltion. Has anyone had this problem before or know what is up with this?
Old 28th February 2008, 01:52 AM   (permalink)
You can also use a single transistor. But doing so usually reguires a great level difference between the two input frequencies. Mixing requires operating in a non-linear mode. With a balanced mixer the output is generally only the sum and difference of the input frequencies. Using a conventional mixer(unbalanced) the output has four frequencies. The sum and difference and the two input frequencies. The low pass filter only passes the difference which I assume in this case is going to be an audio frequency. A good balanced mixer is the SA602 or the SA612.
k7elp60 is offline
Old 28th February 2008, 06:35 AM   (permalink)
See my comment on your other thread.
Ron
Roff is offline
Metal Detector phadkeap Electronic Projects Design/Ideas/Reviews 3 15th September 2006 02:38 PM
metal dector robot (10 cm distant perception) itsmyturn Robotics Chat 1 8th April 2005 09:48 AM
metal detection from 10 cm distance itsmyturn General Electronics Chat 2 18th March 2005 06:58 PM
Temperature coefficient of metal film resistor eblc1388 General Electronics Chat 2 18th February 2005 06:45 PM
Need help grounding some exposed metal. RisingFire Electronic Projects Design/Ideas/Reviews 6 30th January 2003 07:17 AM
