Old 27th February 2008, 02:50 PM   (permalink)
Default doubt on op-amps
in some op-amps (say the uA741), some pins are shown as NC (No Connection pins)...
if at all certain input is given to this pin, will it deteriorate the working of the circuit in which the op-amps are placed???
for example.... if i ground all the NC pins, will the operation of the circuit be spoiled?? kindly help....
raviram87 is offline
Old 27th February 2008, 03:09 PM   (permalink)
“will the operation of the circuit be spoiled??”
The answer is defiantly YES or NO.
Some ICs, the NC pins are not connected inside the part.
Some ICs, the NC pins are connected to test points inside the part and should not be used.
Some ICs, the NC pins are connected to the substrate.
It is never clear if the pins are not connected or if they have a hidden function and YOU should not use them.
ronsimpson is offline
Op Amp vs Single Transistor Amps dknguyen General Electronics Chat 19 12th January 2008 07:31 PM
Where can I find a ammeter that will measure high amps? Nicksan General Electronics Chat 13 12th August 2007 10:31 AM
New forum about building/modifying SS guitar amps joecool85 General Electronics Chat 2 26th April 2006 01:11 AM
Hot transitors @ 0.5 Amps Screech General Electronics Chat 16 14th October 2005 01:38 AM
Conversion of 0 to 5 Amps current into 0 to 5 Volts junaidatta General Electronics Chat 4 15th May 2005 07:40 PM
