Old 26th February 2008, 09:02 PM   (permalink)
Default USB to TTL help
I have an old GPS unit from an OnStar system and have a couple of diffrent schmatics to hook it up to a computer. My problem is they all call for the RS232 shifter, namely the one from from sparkfun. Any ideas on how to convert that idea to a USB type of shifter as well as being able to use the ground and 5 volt side to power the unit? Any help would be appreciated.
woody is offline   Reply With Quote
Old 26th February 2008, 11:10 PM   (permalink)
3v0
Are you taking about the SparkFun USB Bitwacker? If so are you not wanting to use it because of current limitations.
How much current does the OnStar system draw ?
3v0 is online now   Reply With Quote
Old 27th February 2008, 01:35 AM   (permalink)
Not the SparkFun USB Bitwacker but rather like the RS232 Shifter, just with an USB plug, not the RS232 connector. It will need 5vdc. Here is a link to what I am trying to achieve. CLICK HERE
Old 27th February 2008, 12:15 PM   (permalink)
It looks like those programs are using COM1. Unless you can find a USB program or write one that can interface to Google, I would stick with RS232.
C:\WHUT ?
Beware the asterisk *
ClydeCrashKop is offline   Reply With Quote
Old 27th February 2008, 02:29 PM   (permalink)
3v0
Default No Porgramming Solution
On the PC make the USB look like a COM port. Use a USB>RS232 converter to connect to RS232 shifter which connects to OnStar.
PC side
Microchip has a PC device driver that uses USB but creates a virtual COM port. It will let you use a PC program written for RS232 with a physical USB connection. The UBW instructions help you find and install it.
OnStar side
Get a USB to RS232 converter. If it does not provide the +5 you can open the cable and get it as described in the link you provided.
Power for the module is obtained from a PC USB port. Take a scavenged USB cable and connect the red wire to both the module's +5V pin and the VCC pin of the RS232 Shifter [see diagram above]. The black USB wire is connected to the GND pin of the module and the GND pin of the RS232 Shifter. Now attach the RS232 Shifter to the PC's DB-9 serial port and connect the shifter's RX pin to pin 8 of the module and the shifter's Tx pin to the module's pin 9. Finally, plug the GPS antenna into the module.
Should work and there in no programming.
Most any USB>RS232 converter should work because only the RX and TX signals are used.
Old 28th February 2008, 09:35 PM   (permalink)
Cool, thanks for the help. What did you guys think of the idea on using the onstar gps module?
Old 28th February 2008, 10:33 PM   (permalink)
3v0
Depends on what you are going to do with it?
USB Power hack with DC/DC Converter - am I crazy? chconnor Electronic Projects Design/Ideas/Reviews 14 8th March 2008 09:12 PM
Microchip USB framework (custom driver) data logger HerbertMunch Micro Controllers 14 26th December 2007 01:55 AM
PIC 18F4550 interacing with USB amax Micro Controllers 7 21st December 2007 02:13 PM
Help needed developing USB peripheral using HID class Adester Micro Controllers 4 22nd November 2007 02:42 PM
usb interfacing problems for a waveform generator simonharvey Electronic Projects Design/Ideas/Reviews 0 26th September 2007 11:31 PM
