Old 26th February 2008, 04:04 PM   #16
Originally Posted by pasanlaksiri
Ok I upload a Back side picture
Wow, that is incredibly tidy. I was expecting a mass of wires. Again, well done, a good example of how circuits should be built.
Pommie is offline
Old 26th February 2008, 04:04 PM   #17
Originally Posted by AtomSoft
Ok now i got 4 questions: (kinda stupid but want to make sure)
1. 100nf is equal to .1 uf right?
2. 4k7 is equal to 4.7k right?
3. 330e normal 330 ohm resistor ?
4. That button is a push button right like you press and let go and it goes in & out. (dont know propper name for it)
1. Yes but none polarity cap
2. yes
3. yes
4. Yes micro Push Button Switch
Pasan...
pasanlaksiri is offline
Old 26th February 2008, 04:40 PM   #18
Ok so if i was to build this it would cost me around $5. Wow (of course i would most likely buy double or triple quantities to be safe but still inexpensive.
I wanted to know can i use this relay? http://www.mouser.com/Search/Product...YyZ%2f7w%3d%3d
AtomSoft is offline
Old 26th February 2008, 04:42 PM   #19
Originally Posted by blueroomelectronics
Most IR decoders will work, your TSOP4836 should work fine, just follow the datasheet for the pinout.
A TSOP34838 comes with the Junebug kit. Search the forums here for Junebug and you'll see a Sony SIRC remote decoder project done with the Junebug. The transimitter can be any Sony compatable TV remote.
Just to remind you i will be placing that order we talked about either tonight or tommorow for sure. Cant wait to get that stuff tho. Also i am going to search for it now.
AtomSoft is offline
Old 26th February 2008, 05:28 PM   #20
Its cost me less than $3
Pasan...
Old 26th February 2008, 05:37 PM   #21
DO you think it would be ok if i wap out the TSOP1738 for a TSOP4836 because i cant purchase the TSOP1738 (says obsolete) so can i just swap it out for the one you used?
You can use what ever u want. Just see datasheets for the pinouts as blueroomelectronics said
Pasan...
Old 26th February 2008, 06:19 PM   #22
ok cool. I got alot of reading to do to fully understand this. The only thing i seem to get stuck on is the software part of receiving and decoding the signal(bits).
"The start burst is always 2.4ms wide, followed by a standard space of 0.6ms."
Quoted from http://www.sbprojects.com/knowledge/ir/sirc.htm
Will the pin on the pic just be set to high or low every 0.6ms? Would that be how to determine if command/address is 1 or 0
like:
Start __1____1___0__0___1___0___0___1___0___0___0__0
|||||_||||_||||_|||_|||_||||_|||_|||_||||_|||_|||_ |||_|||
I notice the way its drawn the 1 look like it last longer than the 0.
Basically how does the chip differentiate from a 0 or 1?
Am i over complicating things.
(note i have a memory issue. Maybe thats why i cant understand this i keep forgetting something maybe )
AtomSoft is offline
Old 26th February 2008, 11:04 PM   #23
hey i finally got around to making a little video of IR with a Multimeter. Took a 9v supply some resister to bring it down to about 4.6v then the ir receiver i took off some part i think a xbox remote piece (i own 2 so 1 had to go towards science) lol
http://www.megaupload.com/?d=LR0SN4J0 6.22MB AVI (XVID CODEC)
AtomSoft is offline
Old 27th February 2008, 05:22 AM   #24
Can u upload it to youtube or something
Pasan...
Old 27th February 2008, 05:52 AM   #25
http://www.youtube.com/watch?v=TwxIj2wzJrE
Most important time is 1:06 into movie. If only care about results.
AtomSoft is offline
Old 27th February 2008, 03:04 PM   #26
Where do you shop for components?
I use either Jameco but thinking about Digikey now
AtomSoft is offline
Old 27th February 2008, 03:27 PM   #27
Im buying those from our local market
Pasan...
Old 20th April 2008, 07:48 PM   #28
What type of uc memory is used in this project ? I can write the hex code only to eeprom. Thanks.
dajniuz is offline
Old 20th April 2008, 09:51 PM   #29
A 12F629 was used. You'll need a PIC programmer.
Bill
Smart Kits build Smart People
Old 23rd April 2008, 10:29 PM   #30
I have pic programmer. The software I used is ICprog. But I'm able to write hex file only to eeprom memory, when I'm trying to write to flash memory I get an error.
dajniuz is offline
12f, channel, controller, pic, project, remote
Water level Controller Project TB Electronic Projects Design/Ideas/Reviews 5 18th October 2008 07:25 PM
Sony remote control project Fluff Electronic Projects Design/Ideas/Reviews 1 11th January 2004 02:27 PM
Need help for Remote Control Car CADD project ehscrewdude General Electronics Chat 0 11th January 2004 01:28 AM
Micro controller pinout for stand alone project????? cubdh23 Micro Controllers 3 2nd January 2004 10:56 PM
4 channel IR remote control mengchan Electronic Projects Design/Ideas/Reviews 3 6th July 2003 10:21 AM
