Wondered if anybody has any cheap/simple solutions or links for some basic weather related sensors. Looking for barometric, temperature, and humidity. None have to be particularly accurate, but should be easy to read/interface with a microcontroller (AVR, of course).
From the web so far, Freescale makes an air pressure sensor, but its about $20. Little bit more then I was looking to spend on this whole project. I just need to know if the pressure is rising or falling in whatever range is normal around here. Will look into science fair type projects, remember there were several simple means as a child, perhaps something can be adapted. Accuracy is unimportant. Remember several threads on humidity sensors here, so will do some searching. Temperature is the simplest, several cheap choices, but would like to here some alternatives, as I don't need any accuracy for this project idea. Remember some semiconductors (transistors) can be used, but don't remember the specifics, or if it would have much ranges, or require amplification (digging back 30 years or more hurts my brain...). Guess I should explain the idea (save on some of the questions later). I was thing of an RGB Moodlight type lamp, but each of three LED's brightness is related to the three sensors. Basically a clear sunny day would be of some color range, stormy weather another. Based on what sort of color the lamp is, I should be able to guess what kind of weather to expect. Figure it'll be about as accurate as the local tv news I'm on vacation this week, and currently waiting for the ups guy (chick last time) to deliver a solar panel (need to sign), for a different project. Been thinking about this one for a while, just kind of stuck in my head since I woke up this morning. Damn dog gets me out of bed around 7 am every day I'm off work, by jumping on the bed, across my stomach. Least he hasn't nailed me below the belt yet, but still not a great way to start the day. |
I do not know how to make an inexpensive dry bulb humidity sensor.
For an idea regarding a wet bulb humidity sensor check this page. Should work with most any temp sensor type but I like the 1 wire units.
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) |
http://www.digitemp.com/wetbulb.shtml But thanks for that! |
The requested URL was not found on this server. The link on the referring page seems to be wrong or outdated. Please inform the author of that page about the error. If you think this is a server error, please contact the webmaster. Error 404 www.digitemp.com Mon Feb 25 11:16:55 2008 Apache I've been finding quite a few one wire sensors, still a little above the target. Futurlec had a couple that I'm thinking about, if I don't stumble across something better. Both the humidity and pressure sensor modules are I2C, and also read temperature. One was under $6 the other $10. The price is nice, but about 3 weeks for delivery (if I'm lucky). Found out the is a barometric pressure sensor in cars, unfortunately I junk my three lawn ornaments last December... Still waiting on UPS, should probably check the website and see if it's still on for today. |
Problem is the $20 budget won't go far.
But Bill is right. That is a very small budget to do much more then meausre air temp. With the sort of gadget you want to build the web bulb would be a bad idea but it is the only one you can afford. EDIT: I would LOVE to be wrong on this one.
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 25th February 2008 at 09:53 PM. |
Got the wet-bulb link, don't think it's something I can use for this (have to occasionally add water...), also a lot of PVC, maybe $20 dollars worth of fittings. Really only need a very rough measurement,I can scale and adjust in software. Kind of looks like Futurlec has the best price. Going to search and see if I can find something on the web, that uses the modules. Both do temperature, so with shipping, ought to be around $25. |
You can use a diode or transistor as a real cheap temperature sensor:
http://www.overclockers.com/tips12/ You don't have to use a bridge circuit as the author has done. You just need to bias the diode and an Op-Amp to scale the output into AVR territory. Here is a windspeed indicator that uses no moving parts: http://www.fonema.se/anemom/anemom.html
--- The days of the digital watch are numbered. --- |
You told that accuracy is not an important so In your case I use LM series Temperature sensors 34 or 35.Works fine & also cheap.Its rated upto 100 - 150C but I have measured temperature more than that.
Forgot to tell you can measure the light in the atmosphere too.To determine whether is is night or day time or how dark it is. Use LDR for that, measure the AD reading & apply to the output.Most sun trackers use LDR's as sensors to identify the suns direction. Last edited by Gayan Soyza; 26th February 2008 at 04:57 AM. |
The good part, they give good info on reading from it. I don't do 'C', but should still be able to get some useful bits out of the documentation. Futurlec only has the datasheets. I did find a couple of BASCOM routines for reading the sensors. Didn't see a routine for reading temperature in them, but was just a quick look. Thanks for the other suggestions for windspeed and light sensors. Not really looking to build a weatherstation in the backyard sense, this is more a desktop or shelf. While searching, I ended up at the Edmund Scientific website. Remembered they had really cool, but expensive stuff when I was a kid. Didn't find anything I could use, but found they have something similar to what I'm working on. Theirs is hooked up to the internet, and the lamp color is set by whatever it's set to monitor (doesn't have to be weather). Should have grabbed the link, but it really wasn't useful here. Mine will be stand alone, and take its own readings. Will order from Futurlec when I get from walking the dog. Looks like the best deal, and simplest modules availiable. Kind of a cool bonus that I can take a temperature reading from either the humidity or pressure sensor. Saves me time, money, and I/O pins, likely some code as well. This is coming together quite well. |
Will have about a three week wait on the modules, so a good time to get on building a simple LCD serial display/terminal. I downloaded the project files a while ago, figured it be a good tool to have, just never got around to it. |
I placed my Futurlec order a couple of hours ago. Came to $105.05, with the 'Express Shipping' ($16). It says 3-6 days, where standard shipping was about $9 and 2-3 weeks. Figured I'd give it a shot, still expect about 2 weeks until delivery. I got two of each sensor, but mostly I stocked up on sockets, plugs, and connectors, crystals, and few other odds and ends that I always seem to forget.
Harvey,
Are you aware that the SH15 is not an I²C device, although it appears to be very similar. Mike. |
| Weather station controller? | wellu_ | Micro Controllers | 5 | 12th October 2007 08:03 PM |
| Line Detection Robot using PIC16F877 | helmyshahryl | Micro Controllers | 0 | 28th August 2007 01:53 AM |
| Two sensors, one interrupt pin!!! | 2camjohn | General Electronics Chat | 8 | 11th August 2004 01:12 AM |
| Electronic Weather Station Project | Kevin Gallagher | Electronic Projects Design/Ideas/Reviews | 2 | 28th April 2004 11:01 PM |
| Weather station | ala199 | Electronic Projects Design/Ideas/Reviews | 7 | 17th March 2004 01:46 AM |
