HH10D Humidity Sensor $9.90 HP01D Barometer Pressure Sensor - HP01D $5.50 CRY32 32.768kHz Crystal $0.75 Should have everything else already. Most of this order was connectors (IDC, header sockets), and a few other odds and ends that are getting scarce around here. Futurlec has the best prices on these, and don't order often. | ||
| Sounds like you still need more parts, a microcontroller, PCB? | |
I make my own PCBs (toner transfer). I have on hand; ATtiny11, 13, and 85, but only 8 pin so not suitable Attiny2313 and Attiny26, either should work for this, thinking 2313 have more Atmega48, only have 4, and kind still working on that project... Also have some PICs, no idea why I save them. Pulled them out of something I scrapped, cable box or something. Hardware shouldn't be a problem, need to read up on SPI and I2C, the MCU datasheets, and get ready. | ||
| Found an interesting bit on Atmel's website. There was an appnote about thermally correcting the ADC. Seems some AVR chips have a built in temperature sensor (diode), which can be read, and used with the ADC. Didn't see a list of chips in the PDF, but will look for it when I looking through the data sheets. We had some thunderstorms yesterday, was kind of thinking about a lightning strike indicator. Probably a little too much for this project, something to add on later after this is built. Have had some thoughts on the temperature reading though. Measuring indoor temperature probably wouldn't be the most useful, since most people use heating/AC to maintain a certain range of comfort. Also will need some method of adjusting min/max range for each sensor, and set the scale according to what is most useful. Maybe I can make it self learning in software, just store the lowest/highest readings in EEPROM. Wonder if all this will fit in 2k, or if I'll need to move up to a bigger chip. | |
| Lightning strike indicator is a good idea. I hadn't thought about that for mine. Should be very easy. A small antena from radio or even a piece of wire, feed that to a simple diode detector and maybe and op-amp. Should be able to pick those babies up easy enough. Michael | |
| How are you going to run the data from the sensors? I2C is not terribly fond of long cable lengths. | |
The lamp should stay in the same basic color range for the various weather conditions. A radical color change, would indicate storms coming... | ||
| Sounds like you only really need to pay attention to the Barometer Pressure Sensor. Typically, impending storms or bad weather can be detected by the relatively fast drop in barometric pressure: http://www.weatherhut.com/site/12989...metricPressure
__________________ --- The days of the digital watch are numbered. --- | |
| Harvey would not want to use this but others may find the hair hygrometer of interest. Hair changes length depending on humidity. On more humid days, hair will lengthen. The diagram below shows a simple hair hygrometer. It takes about a foot of hair to create a sensor but it could be wound around a pulley or two to decrease the length. The pointer could be used to block light between a LED and a photo transistor for sensing. Image about.com. EDIT: Horse hair can also be used and may be more durable.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 28th February 2008 at 02:02 PM. | |
Think about it. Unless you're fanning doors or have windows open the inside is isolated from the outside. Plus if you're running either A/C or heat it's going to change even more depending on the type of heat. It will try to even out but it usually takes quite a long time based on how much air flows in and out of the house. If you're dead set on it being inside you could set it on a window sill with a window cracked open to get as close as possible. Michael | ||
The readings I take, will be crunched down to an 8 bit value, to set the pulse width for each color of an RGB Led. Hopefully, I'll notice which colors and intensities indicate what sort of weather to expect. Could turn out to be as useless as the local TV news, or might make for a pretty neat gadget. Wonder if some Chinese company will have something like this on the market, before I get my parts from Futurlec? | ||
| Weather station controller? | wellu_ | Micro Controllers | 5 | 12th October 2007 09:03 PM |
| Line Detection Robot using PIC16F877 | helmyshahryl | Micro Controllers | 0 | 28th August 2007 02:54 AM |
| Two sensors, one interrupt pin!!! | 2camjohn | General Electronics Chat | 8 | 11th August 2004 02:12 AM |
| Electronic Weather Station Project | Kevin Gallagher | Electronic Projects Design/Ideas/Reviews | 2 | 29th April 2004 12:01 AM |
| Weather station | ala199 | Electronic Projects Design/Ideas/Reviews | 7 | 17th March 2004 02:46 AM |
