Notices
Old 25th February 2008, 03:22 AM   (permalink (permalink))
Default Tracking device
Before I go and put these designs to P.C.B. thought I would ask if somebody if they can look over these designs check them for me Please.
I have put them as attachments.
Try to use Print Screen and Paint but the paste was grayed out could not use it.
anticpation of you Help
Thank You
peter5355 is offline
Old 25th February 2008, 03:42 AM   (permalink (permalink))
I've fixed one problem, in yellow, on the schematic. The PCBs are too small to see properly and seem to be missing a layer?:
kchriste is offline
Old 26th February 2008, 11:36 PM   (permalink (permalink))
Thank you for your reply I will fix that fault.
what did you mean another layer?
Old 27th February 2008, 04:20 AM   (permalink (permalink))
You forgot to post the bottom layer. You've shown the top layer twice though.
kchriste is offline
Old 27th February 2008, 05:18 AM   (permalink (permalink))
Your ground plane doesn't seem to be connected to anything.
Ron
Roff is online now
Old 27th February 2008, 08:27 AM   (permalink (permalink))
Smile Back to the drawing board
Attachment 17638
The original design used one IC 556 I tryed to convert by using two IC 555 the reason I tryed to convert it is could not understand the design.
I will put the disign into the program I use and convert it.
Thank you for your help.
Old 27th February 2008, 10:26 AM   (permalink (permalink))
Default New Design
Originally Posted by peter5355
Attachment 17638
Have went back to the drawing board tryed to use the ic 556 which is on the previous post
please please help me with this project
Peter
Old 27th February 2008, 11:07 AM   (permalink (permalink))
Default IC 556 Schematic diagram
Peter
Have included Schematic Diagram for the Chip 556 Timer any help you can give me on this matter would be much appriciated.
Peter
Old 27th February 2008, 03:34 PM   (permalink (permalink))
Peter
You have your tuning capacitor in series with your inductor, which will never work. Go back to having it in parallel.
Your reply to my comment about the ground plane being floating was a non sequitur. You need to connect everything that goes to your negative battery terminal to the ground plane. You won't need to connect this node on the bottom side of the board if you do that. You can use thermal reliefs at each connection.
Ron
Roff is online now
Old 28th February 2008, 11:21 AM   (permalink (permalink))
You are correct I have put the tuning capacitor in series will fix that soon but thank you for letting me know about it that could have been a disaster.
I am still trying to get to grips with the CAD program PCB Wizard 3 as you already know I have not set it up properly that is because I don't know how to if you can help me with setting up CAD program PCB Wizard 3 that would be great I will try and do it myself today.
I need to set up the thermal reliefs on the Pads and different colours for the + rails - rails is there anything else that I need to set up in CAD Program
Thank you for all your help so far
Peter
Old 28th February 2008, 03:52 PM   (permalink (permalink))
Maybe someone else is familiar with PCB Wizard 3.
Ron
Roff is online now
Old 29th February 2008, 10:35 AM   (permalink (permalink))
Default Thank you
Could you please look at these designs tell me what you think.
Thank you for all your help it means a lot to me.
Old 1st March 2008, 05:00 AM   (permalink (permalink))
A schematic would be helpful.
Ron
Roff is online now
Old 2nd March 2008, 09:45 AM   (permalink (permalink))
Thumbs up Schematic
Track1 in the attachment is the Schematic thank you for your help
Old 2nd March 2008, 03:46 PM   (permalink (permalink))
So what is this supposed to be? Your schematic has two 555s in it, but you have one 14 pin IC in your layout. If you're going to provide a schematic, it needs to match your layout.
You seem to have confused the + and - terminals of your battery.
What kind of transistor is that? Different types have different pinouts.
There is a questionable connection in your schematic (see below). Is it connected, or not?
Ron
Roff is online now
light tracking device panofish Electronic Projects Design/Ideas/Reviews 4 24th December 2007 06:42 PM
I want to make a short range tracking device , small size, and see 3D position on PC prabhatkr Electronic Projects Design/Ideas/Reviews 8 11th December 2007 02:34 PM
Question about Inchworm+ Quan Micro Controllers 54 28th October 2007 12:20 AM
tracking device mir_borel Electronic Projects Design/Ideas/Reviews 3 8th February 2006 03:25 AM
Viability of tracking device Glyph Chit-Chat 3 25th August 2005 06:33 PM
