Old 24th February 2008, 05:42 AM   (permalink)
Default Activate relay every other input pulse
Hi every one I am new to the forum and I hope you will help me.
I am building a project that requires a circuit that will activate a relay from every other input pulse. I would be using a magnetic switch activated from magnets mounted on a spinning wheel that will be rotating At low RPM.
Cheep and Easy is best!
Your help sure would be welcome.
Thanks Hardhead:
Hardhead is offline
Old 24th February 2008, 07:01 AM   (permalink)
You need a divide by 2 counter, better known as a D-Type flip flop. Have a look here. A common D-Type FF is the 74LS74, this actually contains 2 flip flops.
Pommie is online now
Old 24th February 2008, 01:31 PM   (permalink)
I'd recommend the CD4013 because it has a wider voltage rating.
You can use a MOSFET like the 2N7000 or a BJT like the 2N2222A to drive the relay.
Screen name: Aloone_Jonez
Hero999 is offline
Old 24th February 2008, 10:49 PM   (permalink)
Here is an alternative that avoids ICs.
Len
ljcox is offline
Input Mulitplexer JCrank Electronic Projects Design/Ideas/Reviews 12 19th October 2007 05:52 PM
Output = Input - Problems adamthole Micro Controllers 20 24th April 2007 05:09 AM
relay activation using IC or any circuit jaikanth General Electronics Chat 3 29th December 2004 12:32 AM
using 8051 as pulse counter waqar Electronic Projects Design/Ideas/Reviews 0 13th March 2003 05:06 PM
