| Hi, I need a 12 pulse every time 12v comes on, for a friends car im looking at, when you unlock the cars 12 volts stay on and when you lock the car the 12 volts swap over to the lock wire, now i need a pulse each time the power swaps over, i have looked into the 555 timer but i cant work out how to get a pulse, I am using a program "ciruit wizard" any help would be great. | |
| planty, Attached is a circuit that I helped a student with, to detect the daily activity of 3mm blind cave fish. The input has been modified to detect positive going 12v levels...as in your lock system. I think this will do it. Ken
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) | |
| Thanks for that, but thats a bit much i think, just a basic kit when i recive 12volts i just need a pulse. Then i can just make another one for the other lock... | |
| Hi Planty, Is this simple enough ? on1aag. | |
| OK...a little less complicated. RA and CA can be paralleled with as many lock/unlock inputs (RB/CB, RC/CC....RX/CX) as needed. Whenever one lock/unlock changes there is a fixed width pulse out of the 555. Or, if you don't care about the output pulse width...there is one without the 555 monostable. Ken
| on1agg, Could you complete your schematic with two inputs, one from a 12v locK wire and one from a 12V unlock wire, as in planty's original description. Lock is always high or unlock is always high, and with positive output pulse as in your signal display for the "change over". I might be just missing something in your approach. planty: And not knowing what you are going to do with the 12v pulse...one more with even less. Ken
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) Last edited by KMoffett; 24th February 2008 at 01:53 AM. | |
try the other one now | ||
Thanks | ||
| Hi Planty, O.K. now it's stereo ! on1aag. | |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 06:35 PM |
| Pulse relay driven by MCU needed | r-evil-s | Electronic Projects Design/Ideas/Reviews | 1 | 3rd July 2007 08:30 PM |
| Describe whats going on in this circuit | tru_cutru | General Electronics Chat | 24 | 1st June 2007 02:13 AM |
| Problem measuring pulse width - 12F683 TMR1, 8MHz | jess | Micro Controllers | 18 | 5th February 2007 11:00 AM |
| 12vdc -> 7.5vdc transformer | gulaz | Electronic Projects Design/Ideas/Reviews | 10 | 7th May 2004 08:59 PM |
