Old 6th October 2003, 07:03 PM   (permalink)
Default Heating Element for battery operated heater
Does anyone know how i can create a low voltage heating element. I took wire and coiled it and it seems to be working but the resistance across the coil is only about 1 ohm, and i am afraid that it will drain the battery too fast. Any idea on how i can raise the resistance of the coil or how to make a different heat element?
strunzo123 is offline
Old 6th October 2003, 08:48 PM   (permalink)
This depend from battery voltage and heating power requirement.
If You have a 12V 60Ah battery, the 1ohm wire suck 12A, this is 144W.
With the full carged good battery can work about 5 hours.
Sebi is offline
Old 7th October 2003, 12:24 PM   (permalink)
How much heat do you want - if you know that you can predict battery life.
Ni-chrome wire is one way to get the job done. It has a very high resistance per foot.
An alternative could be as simple as a resistor of the correct value. A light bulb is another.
Let us know more about what you are doing and maybe some other ideas will surface.
stevez
stevez is offline
Old 7th October 2003, 02:08 PM   (permalink)
its funny i asked someone who works with heaters last night at work and they also mentioned ni-chrome....where can i buy some of that wire though?
Old 7th October 2003, 06:47 PM   (permalink)
Wholesale Parts and Film in Readyville, Tennesee, USA lists a bunch of it on their website. I am sure there are plenty of others.
I picked up a 500 ft spool of 30 ga for $1 at a junk sale.
There should be information available on the resistance per unit length for various diameters of wire. You can then determine how much wire you need. Note that if you intend for the wire to get very hot then the resistance will change with temperature. My guess is that the manufacturer's might have the data you need and possibly some applications information.
stevez
stevez is offline
Old 7th October 2003, 06:56 PM   (permalink)
WireTronic website has some good technical info including resistance charts.
stevez
stevez is offline
