| Hi all, I am in need of help with a circuit I would like to build. I can build an electronic circuit no problems but design them I cant. What I am wanting to do is have a single push button switch that will have 4 different stages. I have a 12v battery, on the first push of the button I want to ramp up from 0 to 8vdc (+/- 2 second ramp time) , the second push of the button I would like to ramp from 8vdc to 10vdc (also a 2 second ramp) the third push will ramp from 10vdc to 12vdc (also 2 second ramp) on the forth push of the button I would like to switch the circuit off and reset. Should I push the button again I want to start all over. If anyone could give me some advice as to where I can start searching for help on this and what I should search for. Thanks in advance Sean | |
| What I suggest is this:- Find an adjustable voltage regulator that has a reference / feedback voltage to ground. These are usually 1.25 V to ground. LP2952 is one type. There are normally 2 resistors connected to the feedback point. One is to ground and one is to the output voltage. You need to have a third resistor connected between the feedback point and a control signal. The control signal would come from an output pin microcontroller. The microcontroller output will have a variable duty cycle, to control the voltage. There has to be a capacitor to smooth the duty cycle and make it a variable voltage. The pushbutton would go to a microcontroller input. You need R1, R2 = 10 k R3 = 7.7 k R4 = 48k if you are using a voltage regulator with a 1.25V feedback. R5 can be just about anything. C1 should be about 100 µF The pic program needs to remember what part of the cycle you are in, and it needs to produce a variable mark-space ratio. The bigger the mark-space ratio, the smaller the output voltage, but this circuit has the advantage that there is a linear relationship between mark-space ratio and voltage. | |
| this will be driving a 50w lamp. | |
| Then use a PWM circuit to control the brightness rather than messing around with trying to vary the voltage.
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 06:35 PM |
| boost converter overshoot / undershoot | justDIY | General Electronics Chat | 17 | 21st December 2006 05:50 PM |
| I am not getting ripple voltage at the output | dar2525 | General Electronics Chat | 3 | 14th July 2005 03:21 PM |
| making a voltage / amp tester with a pic 16C711-04 | terramir | Micro Controllers | 10 | 24th July 2004 11:23 AM |
| convertion of acvoltage to high dcvoltage | panchumarthy | Electronic Projects Design/Ideas/Reviews | 8 | 12th December 2003 02:36 PM |
