Old 20th February 2008, 06:00 AM   (permalink)
Default Simple scoreboard
I'm pretty new to this, but in our hockey league, we are looking for a ultra cheap scoreboard for indoor hockey...
I've been looking around the net, and found a good-size single-digit display (7" - http://www.a1parts.com/digitdisplay/index.htm) to use
Minimum req' would be something like
-  Home   Time   Away  -
-  00    00:00    00   -
The counter would need to be able to go down from either 20 or 10 minutes (no need for custom time) and reset. It would but installed on a wall, and would need an external control (lower on the wall)
If possible
  • Short buzz when at '00:00'.
  • 3 lights for periods if possible
  • Custom time reset if possible to implement, but this would be because we are playing indoor hockey in a small shool gymnasium, and we would give the board to them... So a custom time reset could be usefull for them.
Control box could be like
  • Time reset (press one 10:00, press again for 20:00)
  • Score reset
  • Start time
  • Team 1 - Add a goal
  • Team 2 - Add a goal
  • Period 3-way switch
  • Power on/off
I tough of purchasing a pre-built one, but those cost a lot and too much features for what we need.
I'm pretty good on working with my own hands, but wondering how this could be done (electronic-side)?
I'm open for suggestions, if there are better way or parts to do this.
Thanks!
Olivier
Y2Breeze is offline
Old 22nd February 2008, 11:33 PM   (permalink)
I suppose a microcontroller is the only sensible way of going about this.
Screen name: Aloone_Jonez
Hero999 is offline
Old 23rd February 2008, 12:22 AM   (permalink)
I'd agree. I built my first digital circuit (a foosball scoreboard circuit) using TTL logic over the past couple of years. It is big, slow, and uses too much power--but it does work.
It took ages to design and I had a ton of help from Ron (Roff) , Eric Gibbs, Nigel, audioguru, and I'm sure many others I'm forgetting right now. I learned a lot--enough to know that while it was a fun project and I learned a lot, it would be much faster to build, debug, design, and modify after the fact by using a microcontroller.
I've attached a photo of the completed boards. Ron, you can see the differentiators you instructed me on, on the left-hand board (four identical subcircuits with pigtails for the score/win lamps and RCA outs for the SPD-20 triggers--thought you might like to know I actually used the help you so patiently gave me.)
Torben
[Edit: I need another coffee. Ron hasn't posted to this thread at all. ]
Torben is offline
Old 23rd February 2008, 02:03 PM   (permalink)
It still looks good anyway.
What did you use to power it?
I suppose a wall wart or large sealed lead acid battery are the only viable options.
Hero999 is offline
Old 23rd February 2008, 07:42 PM   (permalink)
Thanks Hero,
I put a wall-wart type plug on it and used a 12V 1A linear supply I'd built for something else (a Fostex 4-track recorder I never got around to fixing).
Torben
Torben is offline
Old 23rd February 2008, 10:06 PM   (permalink)
. . .and back to the topic at hand.
Y2Breeze, how much do you have to spend on this?
How much time do you have to design and build?
What (if any) parts do you already have (displays, etc)?
If you like I can work on some code for this. I have some older cheap microcontrollers; I could most likely fit the required code onto one of those and mail it to you if you like. This project shouldn't need much in the way of fancy chip features and I like to support local sports/schools.
Other things like the switches, displays, power supply, housing etc. you might be able to scrounge from scrap/used appliances etc. For the switches my first thought would be that you'd want something which can take a beating, especially if you're going to let the school kids at it. Big arcade-game style buttons and switches are meant to last forever but also cost quite a bit.
Torben
Torben is offline
Simple DJ BPM Counter derrickr Electronic Projects Design/Ideas/Reviews 9 18th August 2008 09:19 AM
Need help to make simple scoreboard with LEDs rydad Electronic Projects Design/Ideas/Reviews 10 14th April 2008 09:45 AM
Simple Robot From Scratch Parts? GreenAce92 Robotics Chat 7 28th October 2007 12:42 AM
little help with my program please - simple count loop kud0s Micro Controllers 5 7th July 2005 10:40 PM
simple help.. Making a simple amplifier. pls help urgent. paulbostaph General Electronics Chat 19 20th May 2003 05:32 PM
