| hi, we designed an electronic card which is supplied by a dc adapter(i.e. no safety ground connection). the card is in a box and the box is shielded. i wonder where should i connect the shield? because there is no earth connection. | |
| The shield can function correctly even if it is not earthed. In your situation it might be best to connect the shield to the circuit reference on the card (ie. DC ground). However, it would be useful to know a few things first. Are there cables passing into and out of the box? Is it likely that a person would touch the sheild metal in normal use? Is the sheild there for a specific purpose, or just general protection?
__________________ RadioRon | |
| the shield is for emc purposes. to block em waves. does it function properly if i connect it to the DC ground? | |
| The best bet would be to get a real earth (not the articial "earth" taken from neutral) shield connected to the box. The shielded cable should only be connected at the box to leave the other end unconnected. The shielding in that particular case is not AF which requires shielding on both sides. Shielding AF cables on both sides is a cripple. A third neutral wire and an extra shielding is much better. | |
| connect the pic16f877 with an adapter usb bluetooth | lm85 | Micro Controllers | 6 | 7th June 2007 07:22 PM |
| Unable to connect to Inchworm | Hedos | Micro Controllers | 15 | 23rd December 2006 04:26 PM |
| How to connect LED detector 2 Pins?..program microcontroller | Terrano | General Electronics Chat | 3 | 31st March 2005 05:38 PM |
| Connect Battery and PSU at same time...? | grrr_arrghh | General Electronics Chat | 3 | 10th July 2004 12:20 AM |
| Please Help. How connect Pass Transistors in (-) Regulator? | hamfiles | Electronic Projects Design/Ideas/Reviews | 2 | 23rd June 2003 07:27 PM |
