Hi everyone,
I'm currently building a small SCADA for my house, using a computer as supervisor and connecting it to a PIC via the serial port. The first step will be to control the air conditioners (I have two in my living room). I have tested the PIC and it does communicate successfully with the computer, and also can control one A/C perfectly. However, I have two EMC problems, and I wanted to get your opinions: 1) I use PWM at 38 kHz to control the A/C. I multiplex the CCP output using a 74HC00 to be able to selectively control one, the other or both A/Cs. This goes to a 7 m cable that feeds both power and signal (+5V,GND, PWM output) to an NPN transistor controlling an IR LED. However, the A/Cs don't recognize the IR commands (they do when I don't use the cable). Is there a simple fix for this? 2) In the final configuration, I will be placing the PIC around 10 m away (make that 15 m of cable) from the computer. I've read somewhere that this is pretty much the limit for RS-232, and was thinking of using RS-432. On the µcontroller side, the PIC won't even notice if I replace the MAX232 for a MAX488. However, can I use a MAX488, suitably connected to the computer serial port to "translate" back to RS-232? Thanks a lot! |
(permalink) | |||
Instead of putting the transistor at the LED end of the cable, put it at the74HC00 end of the cable and just use two wires (twin-twisted) to connect the transistor to the LED. I think you will find that the current drive to the LED will work better than the voltage drive to the transistor. Quote:
If you are using a high speed, 19200 bps or more, then yes you could have a problem. But if the comms link is run a a slow speed, RS232 will be fine. How fast does the link have to be, I guess not very fast. Try 300 bps, it will probably work well. Quote:
But be aware that the MAX488 does not directly interface to RS232 on its "single ended side", you would probably have to use a MAX232 to get the correct voltage levels for RS232. Lots of hardware when a slow RS232 link will probably do it all for free! JimB
Experience is directly proportional to the value of the equipment ruined. |
Thanks a lot for your answers!!!
You used PWM to control an airconditionar?
What sort of motor does the A/C use? I thought they normally used induction motors which can't be controlled using PWM.
| Piezo + electromagnetic preamp | steven_first_2001 | Electronic Projects Design/Ideas/Reviews | 2 | 25th October 2007 07:00 PM |
| Electromagnetic field interference. | bananasiong | Electronic Projects Design/Ideas/Reviews | 2 | 11th June 2006 02:33 PM |
| TV interference | mstechca | General Electronics Chat | 6 | 11th July 2005 12:02 PM |
| Destructive Interference and Active Noise Control | Johnson777717 | General Electronics Chat | 7 | 23rd June 2004 06:26 AM |
| Newbie with interference! | OzWold | Electronic Projects Design/Ideas/Reviews | 5 | 28th January 2004 12:42 PM |
