| Hi again I have built a circuit with a PIC 16F627 and a MAX232CPE, I use the hardware USART on the PIC, which is connected to the MAC232CPE (RS232 chip). Now I want to add two status LEDs to the RX and TX, so that when the line goes high (logic high), the LEDs lights up. I don't want to put anything in there to affect coms between the chips. Anu suggestions? | |
| Just resistors and LED's on the lines, certainly the PIC is well able to drive a LED, and the MAX232 should be OK as long as you don't try and draw excessive current off of it - so don't run the LED's too bright. You used to be able to buy RS232 monitors (and probably still can?), which plugged in the RS232 side and had LED's for all lines - I've still got one. | |
| Ok, cheers Nigel. I will do that. I guess the PIC side shouldn't be a problem (25mA), just unsure about the MAX232 side. I've got one RS232 line monitor too BTW, it's on the TTL side, not the RS232 side. | |
| Introduction to High Brightness LEDs and Thermal Management | Ocelaris | Electronic Projects Design/Ideas/Reviews | 3 | 17th March 2007 06:35 AM |
| Problems with Dual Brightness (Current) LED Tail Lights? Eagle Schematics! | Ocelaris | Electronic Projects Design/Ideas/Reviews | 12 | 31st December 2006 07:18 PM |
| A Basic Question of Efficiency - 4 LEDs in parallel or series!?! | Agent M | Electronic Projects Design/Ideas/Reviews | 9 | 27th December 2006 04:23 PM |
