| hi i want to convert 12v dc to 48v dc, i have a ups it works with four batteries i want to convert it to a sibgle battrey 12v plzzz help me any one having circuit diagram | |
| Use a switchmode power supply IC. Some of the manufacturers have wizards on their websites that'll design the circuit for you, just enter what input, output voltage and current you require and all the hard work will be done for you. http://www.linear.com/pc/viewCategor...03,C1042,C1031 http://www.national.com/appinfo/power/ http://para.maxim-ic.com/cache/en/results/4631.html
| ok if its not good idea then wat about 24v dc to 48v dc plzz post the circuits diagram i wana make it my self!!! @hero999 thnx 4 the sites but the solution is not avalilable is there some more plzz | |
| can 1 battery work? will the load power imply an excessive amount of current from a 12V source? The 48V may be there as a standard (48V is a common voltage). it may be done to keep current down. 24 to 48V is fairly easy. especially without isolation. A pushpull wired up with just the primaries will give 2x voltage. | |
| How much power do you need to convert? You should be aware that every 1A of 48V is going to need about 5A of 12V. (Assuming 80% efficiency). For example if your ups is 1kVA, it probably needs 25-35A at 48V, so it would need 125-180A from 12V. | |
| controll ing dc motor need help | norms09 | General Electronics Chat | 14 | 5th August 2008 01:37 PM |
| How to get 3.3v to 12v for a project?? | hittinswitches98 | Electronic Projects Design/Ideas/Reviews | 6 | 1st December 2007 08:44 AM |
| 12v to 7.2v Voltage Regulator | jimbo93 | Electronic Projects Design/Ideas/Reviews | 4 | 19th November 2007 06:33 AM |
| Can you help me for Isolated DC to DC | gbmewada | General Electronics Chat | 7 | 15th October 2007 08:00 AM |
| Convert 12V DC to 220V AC | micpic | Electronic Projects Design/Ideas/Reviews | 17 | 15th September 2007 03:03 AM |
