| Here is an example of the circuit. The coil restance is 240Ohm and the current without limiting resistor is 56.1mA. With limiting resistor the initial current is high until the cap is discharged. Thereafter the current drops to 37.3mA. Coils with higher restistance require a higher value limiting resistor for optimum power saving. To hold the relay the capacitor has no influence. Last edited by Boncuk; 8th July 2008 at 12:49 AM. | |
| I could double the frequency to 150Hz or 300Hz. | |
| Maybe you answered this before, but I missed it. Why not use a latching bi-stable relay. There is a choice of single- coil of two-coil, depending on how you want it to switch. I was surprised the DigiKey price for the Schrack is only $2.50. http://relays.tycoelectronics.com/sc...bistable_d.pdf John | |
| I think it's a good idea. The minimum frequency depends on the relay's resistance, inducatance and minimum holding current. You probably already know the resistance and possibly the minimum holding current, the only thing you need to measure is the inductance. Also use a Shottky diode as it'll reduce the losses and alow the duty to be reduced even further.
| I'll be using a latching relay in the next kit after ladybug (PLC & Ethernect). Cricket (RS485 Thermostat with 2.5 digit LCD) Here are the relays I plan to use. | |
| Variable capacitor circuits | walters | General Electronics Chat | 83 | 11th March 2008 03:59 PM |
| Need a relay controller | rtm038 | Electronic Projects Design/Ideas/Reviews | 14 | 18th November 2007 06:20 AM |
| Optimal quench frequency | mstechca | General Electronics Chat | 1 | 1st July 2005 06:13 AM |
| Relay Connections | Johnson777717 | General Electronics Chat | 2 | 7th July 2004 10:45 PM |
| Incubator Relay Circuit | Plip | Electronic Projects Design/Ideas/Reviews | 2 | 26th November 2003 01:36 PM |
