| Is FM modulation possible using 566IC? I wanted to know whether it is possible to modulate FM using 566 IC.. ? If its possible, can you people guide me how it can be done?.. If its possible, Can I get a link for a sample circuit?.. Your help will do good lots for me as I'm doing this as a college project where i'm supposed to use 566IC. Waiting for your replies,eagerly.. Thanks.. | |
| Yes it is possible to generate the FM signal with LM566.... The LM566C can be used to generate FM signals upto 1MHz range.. U have to pass the modulation signal through pin number 5 (if am right)... I believe that all information u need would be given in the datasheet of LM566 which i have attached below.... I feel that the timing resistor and capacitor pins (pins 6 and 7) decide the center frequency which can be determined using the equation given in page2 of datasheet... once u get the FM signal, u can probably attenuate it, remove noises (LP filter) and then transmit it.... | |
If you can help me with the designing of circuit.. I'll be really happy and thankful.. | ||
| The NE566 can go even higher than 1MHz, if you use a harmonic filter but this will only work up to 10MHz at the most. The NE566 is not good as an FM radio transmitter which would require at least 88MHz and is much easier to achieve with a discrete design.
| I want to develop a FM Radio- plz Help | soumyadip | Electronic Projects Design/Ideas/Reviews | 3 | 29th January 2008 06:09 PM |
| Help to develop a PLL circuit to demodulate FM | soumyadip | Electronic Projects Design/Ideas/Reviews | 3 | 22nd January 2008 02:10 AM |
| FM Radio Kit Schematics Help | BHaselman | Electronic Projects Design/Ideas/Reviews | 14 | 31st October 2007 05:22 PM |
| Anti aliasing??? and modulation | andy257 | General Electronics Chat | 5 | 4th January 2005 06:54 AM |
| Newbie modulation question | zachtheterrible | General Electronics Chat | 14 | 7th May 2004 01:22 PM |
