| Hi All, Is there any simple circuit to identify the phase reverse or phase sequence change in a 3 phase (star connected) 440V system? Thanks in advance
__________________ Sqn R.K. Chakravarthy ---------------------- Sky is not the limit for Air Warriors | |
Is there any other simple method, in addition to the one cited below to identify the phase reverse in 3 phase system. Known method: Convert the sine to square using Zero crossing detector and then compare the rising time between the phase using a Micro controller.
__________________ Sqn R.K. Chakravarthy ---------------------- Sky is not the limit for Air Warriors | ||
| What do you want to prove ! The phase sequence is clockwise or anti-clockwise. The only time when a change may happen is when the cables get transposed when a transformer is replaced or a generator is inserted and appropiate before and after tests were not done. Get a phasesequence meter ( for continuous duty ) with optical indicators and sense these with an optocoupler to detect rotation and trigger your alarm or relay. Cheers, Raymond
__________________ There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. | |
Hi Rodalco, I wanted to know , on what principle this stuff work? I have a blower in the workshop, which is driven by the 3phase motor. Some time the phase sequence get change(R Y B) due to other experiment done inside. This is making the blower to work as suction device. I wanted to sense the phase sequence and if the phases are not in the correct sequence ( ie RBY, YRB,BRY etc) , i need to de-energize the relay connected to the motor. Could you please tell me , is there any other easy method to do this inaddition to the one i mentioned earlier ? Thanks for your valuable guidance.
| A simple way would be 2 zero crossing detectors on the R & B phases. The R would trigger a 10mS monostable, if the B detector triggers before the monostable times out then the phases are wrong. Another very good indicator is a fan that runs backward. How on earth do the phases get changed in the first place? Mike. | |
| Go to http://www.edn.com/archives/1998/042398/09di.htm and scroll down to "$5 junk-box circuit determines phase sequence" | |
| Phase difference detector, 433.92MHz | AndyPLL | General Electronics Chat | 25 | 29th November 2008 07:19 AM |
| Variable capacitor circuits | walters | General Electronics Chat | 83 | 11th March 2008 03:59 PM |
| 3 phase electronics | triple_access | Electronic Projects Design/Ideas/Reviews | 22 | 3rd December 2007 09:15 PM |
| Need guidance for earth failure indication | Rajaneesh | Electronic Projects Design/Ideas/Reviews | 23 | 24th July 2007 01:50 PM |
| Measuring Phase | walters | General Electronics Chat | 25 | 3rd December 2005 09:24 AM |
