http://www.allaboutcircuits.com/vol_2/chpt_6/2.html then, with focus on parallel resonant circuit, study this: http://www.allaboutcircuits.com/vol_2/chpt_6/6.html then this to see how to couple into and out of a parallel resonanct circuit http://www.allaboutcircuits.com/vol_2/chpt_8/6.html Then build your model using these principles, plus, when you have three parallel tuned circuits, you can couple from one to the next by using a capacitor at the top of the circuit, but start with a very small value of capacitor, and then gradually increase this capacitor and see the effect on insertion loss and bandwidth.
RadioRon |
RadioRon |
please look at this,
http://knallfunke.de/drm/antennen/mobileloop/index.htm Translation can be done by yahoo translator All the best
Regards, Sarma. |
Imagine that there is no source attached to the input. In that case, the loaded Q of the first tank circuit might be as high as 50 to 100 or more. However, when you attach the 50 ohm source directly to the top of L1 like that, it is identical to putting a 50 ohm resistor in parallel with L1 which dramatically reduces the loaded Q. The fact that the rolloff is slow, and levels out, at frequencies above the center frequency of the filter is due to the same problem. As the frequency goes above 1 MHz, the impedance of the top coupling capacitors C2 and C4 goes lower plus the effect of L1, L2 and L3 disappear and so there is nothing with an increasing impedance vs frequency in the way of the energy, so the output levels out at about -50 dB. The next step to fix these problems is to change the connection point of R1 and of R2. For example, with R1, you should disconnect it from the top of L1 and create a "tap" on L1 about 1/10 from the bottom (that is, 10% of the total number of turns of wire) and then connect R1 to that tap. Similarly, disconnect R2 from C5/L3, create a tap on L3 at the same height as you did for L1, and reconnect R2 there. This method of tapping the coil will improve the impedance match between the 50 ohm source/load and the tank circuit, it will dramatically increase the loaded Q of the first and third tank, and it will cause the ultimate rejection above resonance to keep going down without levelling out. You may adjust the height of the tap for best overall performance, but it should be kept fairly low on the coil. The change in phase at the resonant frequency doesn't matter. Ultimately, you will be operating at only one frequency and your circuits will cause a total phase shift of some unknown amount. It will be necessary to calibrate out this phase shift. The important thing is that the phase shift isn't varying with time, and that won't happen in this circuit.
RadioRon Last edited by RadioRon; 16th February 2008 at 08:46 PM. |
You don't even need to to tap the coil.
Another winding loosly coupled to the coil will do the job - it'll act sa a transformer. In theory you could have the loop outside your house and the coil in front of your bedroom window coupling the energy.
How would you do the sim without a source?
RadioRon |
Next, you can tune the resonant frequency of each of the three tanks circuits to seek the most desireable response. Tuning means to vary either the inductance or capacitance value of each tank circuit a small amount and also the value of the top-coupling capacitors. What is the most desireable response? If you are interested in passing only one sinusoid, at 1.00 MHz and you know this sinusoid is stable, then you can tune your circuit for the most extremely narrow response. If you considered it wise to have a bit more bandwidth in your filter to deal with variabilities then you might choose to tune one tank to exactly 1.000, another tank to 1.001 and another to .999 MHz to flatten the response. This final tuning is up to you. Do not be concerned with a bit of assymettry to the response as you point out. This is harmless. Also, pay no attention to the response below -50 dB because when this filter is built, there will be unexpected parasitic coupling that will limit the response and not allow it to fall below -50 or -60 dB. So, your plot showing attenuation beyond -100 dB is not realistic. This filter is working well. I think that it would be a lot more informative if your x axis were expanded to show performance mainly from 100Khz to 10 MHz.
RadioRon Last edited by RadioRon; 18th February 2008 at 07:00 PM. |
I can observe that the quality factor for most of the inductors sold in the market are around 35 to 45, should i put the corresponding Q of the particular inductor rather than the Q of 80? I am now working on designing the amplifier, is it alright for me to use 2n3904 in the amplifier?
I am now satisfied with the filter response (please refer to the pics, and circuit)... How do you think? I made the capacitors in the CL tank to be in parallel as i cant get a component with such a exact value , is it alright for us to do so? Again, whats the type of connector that i should use to connect all the modules? Last edited by Harros; 21st February 2008 at 06:08 AM. |
| VNA Question | quixotron | General Electronics Chat | 4 | 29th January 2008 06:05 AM |
| Loop Antenna Design and Considerations | quixotron | Electronic Projects Design/Ideas/Reviews | 2 | 29th December 2007 11:14 PM |
| LCD Alarm clock with PIC16F877 ( some pics included ) | pasanlaksiri | Micro Controllers | 10 | 22nd May 2007 10:36 PM |
| Antenna conversion, Loop to Straight wire | heida11 | Electronic Projects Design/Ideas/Reviews | 2 | 17th March 2006 07:12 PM |
