Yes, I am going to work on the PCB layout design right after all the circuits have been confirmed since there are only two months left before my hardware presentation. I will use the fiber glass PCB for PCB etching, is it alright to use this type of PCB in etching?
By the way, I am planning of doing ranging measurement for ~100 meter (About 0.35 lamda. Note: the measurement can reach 0.45 lamda using this system theoretically). Is the transmitter’s power high enough for the purpose? How we can determine the antenna gain if there is no datasheet for the antennas? I cant determine the gain for each stage as I don’t know the antenna gain… Any suggestions on the way to determine the gain for each stage? Regarding the bandpass filter between the amplifier and the phase detector, is it alright to implement a crystal filter there? I have no idea of any filter with better cutoff/ rolloff… I am thinking of putting a 2nd Order Butterworth LP Filter before the ADC input of the MicroController, is it alright for me to do so? Do you have any clues on the op-amp that I should use (I mean the spec of the op-amp)? Preferably the op-amp from TI (Since i can get the sample from there I have enclosed a new diagram of the system, as well as the schematic of the Colpitts Oscillator used in the transmitter... Any comments on the oscillator? Last edited by Harros; 14th February 2008 at 07:27 AM. |
(permalink) | ||||||
The rod antenna is very easy to simulate and I can do that quickly and tell you the gain. But the loop antenna is difficult and I cannot use my simulator for that one. We will have to find out the antenna gain by finding similar antennas that others have built and who have measured their gain figure and reported this in a report or website. This will take some time. Another way is to measure the gain of the antenna. This is possible if we are not too fussy about our accuracy. Can you provide any details about the tx antenna including a picture? Quote:
Do you know how to make a simple crystal oscillator for use as a logic clock? This is usually done with a simple CMOS logic inverter. This would be the ideal oscillator and transmitter for you. Use a HEX Buffer IC (eg 74HCU04) and configure one buffer as a crystal oscillator, then feed the other buffers all in parallel and combine their outputs and then pass the signal through a 1 MHz chebyshev lowpass filter to remove harmonics. This is far simpler and is easy to do. I have seen links in another thread and will look for the example.
RadioRon |
Thank you for your advices. I am now working on redesigning the oscillator with crystal oscillator using 2N2222, but i cant find the oscillator for 1.07 MHz... Do I need to change my operating frequency for the system?
RadioRon |
Do you mean Pierce Oscillator for the oscillator built using HEX Buffer IC and crystal? I have built the circuit of it, but the output suffers from severe distortion... I have built the oscillator using crystal as well... But it is not working...
Again, for the filters, is the enclosed filter is the one in your mind? |
Yes, the second link, Pierce Oscillator using 74HC04 buffer IC is very close to what I was suggesting. It is necessary to put additional buffer amplifiers between the oscillator and the low pass filter to provide enough drive for the low impedance looking into the filter. Connect the remaining five gates in parallel to be this driver. I have built similar to this before and the distortion is low. In any case, distortion is not a problem because your output filter should eliminate all harmonics, which will clean up the waveform to be a sine wave. Your output filter must have at least 20 dB attenuation at 2xfc. If there is not enough power from this kind of circuit, it is easy to add one additional discrete amplifier using an NPN transistor. As for the output filter, your design is ok, but I was thinking of a simpler configuration where L2 and L4 are omitted and C2 and C4 are small value, high impedance. In my simplified configuration, it is necessary to tap into the first resonator made up of L1 and C1 by either tapping into the coil, or using two capacitors to couple in. In this way, the low source impedance does not load the Q of this tank circuit. C2 would be a small value, sufficient to couple energy to L3, C3 which would be resonant. C4 same as C2. The output would also have to tap into the L5,C5 resonator by tapping the coil or by splitting C5 into two values and connecting between them. This type of configuration is simple and easy to tune. You then have three tank circuits that all have high impedance at their tops, and high Q for good selectivity. The loss through such a circuit is reasonably about 2 dB or less.
RadioRon |
Whats the difference between crystal and crystal oscillator? I can hardly purchase a 1MHz crystal at my place, but the 1MHz crystal oscillator is easy to get here...
A crystal oscillator is an active circuit containing several components configured to oscillate when DC power is applied. A crystal is one of the internal components and is used to determine the frequency of the oscillator. Your previous posting had a circuit containing a 2N2222 and a crystal amongst other things. That is an oscillator. The single component shown as a kind of capacitor with a rectangle between the plates, that is a crystal.
RadioRon |
I cant simulate the circuit by connecting the gates in parallel... Why this happens? Any suggestion that I can do to make the simulation runs? I am using MultiSim to perform the simulation.
RadioRon |
The way to estimate your range is as follows:
calculate path loss (PL) = RxSens (dBm)-Ptx(dBm)-Gtx-Grx Since we are in near field, we cannot use typical farfield path loss calculations and so must find the correct forumula to translate PL into distance. In the meantime, let's estimate that your RXSense = -70 dBm, Ptx=17 dBm, Gtx=-16 dBi, and Grx=-16 dBi. This means we can afford a path loss of -55 dB.
RadioRon |
Again, can we just buy a crystal oscillator to provide the sine wave and do amplification to the output of the crystal oscillator?
http://sg.farnell.com/jsp/search/bro...equestid=36149 Last edited by Harros; 15th February 2008 at 03:56 AM. |
Yes, that will work fine.
RadioRon |
RadioRon |
| VNA Question | quixotron | General Electronics Chat | 4 | 29th January 2008 06:05 AM |
| Loop Antenna Design and Considerations | quixotron | Electronic Projects Design/Ideas/Reviews | 2 | 29th December 2007 11:14 PM |
| LCD Alarm clock with PIC16F877 ( some pics included ) | pasanlaksiri | Micro Controllers | 10 | 22nd May 2007 10:36 PM |
| Antenna conversion, Loop to Straight wire | heida11 | Electronic Projects Design/Ideas/Reviews | 2 | 17th March 2006 07:12 PM |
