| I have a 12v DC (continuous) source that holds an exhaust brake on a diesel pick-up closed. The new exhaust brake requires a momentary 12v DC pulse. Is there a simple way to convert a continuous source to momentary? Thanks. | |
| A capacitor in series with a relay coil would work. That's about as simple as you could get. How long does the momentary pulse need to be? How much current does the exhaust brake draw?
__________________ --- The days of the digital watch are numbered. --- | |
| Thats what I figured, just wanted a confirmation. The draw is only the coil on a 12v automotive solenoid. It needs to pulse about a 1/2 second. 12v pos. to coil, 12v neg to capacitor then ground? Last edited by verno; 12th February 2008 at 01:32 AM. | |
| Yup. The size of the capacitor will depend on the relay. With a typical 150
__________________ --- The days of the digital watch are numbered. --- Last edited by kchriste; 12th February 2008 at 02:42 AM. | |
| What voltage rating should the capacitor be? 12v ? | |
| You should always have some margin for error. Choose a 16V one or higher because the charging system on the truck typically will float the battery up around 14.2V when the engine is running.
| You can' get timer relays for this sort of thing.
| Help Needed!!! Print my circuit on PCB!!! | kwon | Datasheet/Parts Requests | 3 | 12th August 2006 01:08 PM |
| Newbee help needed on a 12v circuit. (Swithced resistor) | stubs | Electronic Projects Design/Ideas/Reviews | 13 | 10th January 2006 07:20 PM |
| Help needed in simple circuit design | desmond | Electronic Projects Design/Ideas/Reviews | 5 | 12th April 2004 07:57 PM |
| Circuit Needed Please | jkon | General Electronics Chat | 2 | 19th December 2003 02:39 AM |
| timer circuit needed | n5oxp | Electronic Projects Design/Ideas/Reviews | 34 | 4th September 2003 11:03 PM |
