| Experienced Member | So, where exactly did that 2N7000 go? Mike. |
| Experienced Member | I pulled the 2N7000 as I was not clear how it would affect the Analog input mode when not using a relay (not shown above). You could alway put a 2N7000 where the 2N3904 is. I put the LED directly to the I/O pin to hopefully act as a pulldown (when the I/O is an output ie RESET) as well as an indicator in relay mode. This schematic is one behind the current, I'll update the image ASAP http://www.blueroomelectronics.com/u...February08.htm It's the whole schematic (and I've added an XBEE)! |
| Experienced Member | Here's a closeup with the LED back on RLY power, and the 100K pulldown. ![]() |
| Experienced Member | Quote:
Nice protection of relay contact. A single transient suppressor from the common connection to the return wire of the circuit on the relay contact would do. and you can save a device while still protecting the contact.
__________________ Regards, Sarma. Last edited by mvs sarma; 10th February 2008 at 04:28 PM. | |
| Experienced Member | Many of the resistors prefrom double duty. Rb1 is also used in the analog mode and as a pulldown in direct I/O mode. |
| Experienced Member | Sir, you may try to increase Rk1 to a higher value if the opto is workable.
__________________ Regards, Sarma. |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 09:48 PM |
| Just Joined, Got some bugs I can't find. | Thedoctorisin136 | Micro Controllers | 0 | 1st March 2005 06:07 PM |
| Crazy Resonance Problem | cchalmers | General Electronics Chat | 31 | 14th February 2005 03:46 PM |
| Mismatched load problem for EMC course. | jamesmi | General Electronics Chat | 2 | 14th February 2005 10:43 AM |
| convert input resistance to different output, but how?! | pcoghlan | Electronic Projects Design/Ideas/Reviews | 7 | 9th July 2004 09:59 PM |
