| running a 12v+ & 12V- under 14 pin dip=.030 traces also under same dip 2 ground traces = .020 traces any problems with this?? routing traces etc. is kinda fun but frustrating | |
| Why 2 ground traces? John | |
The fun starts at a trace width of 0.00591 (0.15mm) routing two traces through the gap between two IC pins using the same layer. The distance between traces and pads is 0.15875mm (plenty of room). Don't try to make a good layout with your laser printer. It takes a gerber photoplotter to do this. Hans | ||
| running duel power supply pins 3,5,10,12 all grounded. have power plug at one end, ground traces on outside edges(12+ & 12- run between) at pin 3 (12) I exit, connect to resistors then re enter under the chip via pin 5 (12) continue on to next chip (6 all in a row) at end of row I connected the 2 grounds together as well as at the power plug end. Maybe insert a couple of caps at the end (between 12+ to grd and 12- to grd. a REAL ground loop. If I figure out how to get a pic of the pcb layout I will post. | |
I run 2 traces between IC pads using an Eagle layout printed on my HP1020. Traces are .01 inch (IIRC). Pulsar shows similar examples on their site. Larger Image
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | ||
| 3 Traces between pads ? | 3v0 | General Electronics Chat | 25 | 23rd March 2007 01:19 AM |
| PCB with parallel traces to mount current sensor? | Hobbledehoy | General Electronics Chat | 3 | 13th June 2006 06:18 AM |
| audio traces on a pcb? | justDIY | Electronic Projects Design/Ideas/Reviews | 12 | 10th April 2006 05:31 PM |
| High current/heat DC PCB traces | Oznog | General Electronics Chat | 4 | 29th December 2005 05:21 AM |
| PCB traces | freeskier89 | General Electronics Chat | 13 | 4th December 2005 06:05 AM |
